  1. Hotdog453
    Hotdog453 New Member
    Ohio
    2024 Prius Prime
    XSE Premium
    Hello,
    For our 2024 Prius Prime, I plan to have two sets of tires: Snow and non snow.
    Does the car natively support multiple sets of TPM, assuming they were 'correctly' assigned to the car? IE, in my Subaru, I currently have a tool to 'flash' the sensors to the car, via the OBD2 port each time I swap tires.
    What are people doing with multiple sets of tires/rims?
    I am 100% down to 'buy something' to do this, but didn't see much information floating around out there.
    Thanks!
  2. Hammersmith
    Hammersmith Senior Member
    1,307
    1,334
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The gen5 Prius can handle 2 sets of tires. No scan tools are needed. Everything can be handled through the in-car menu system.
    SM-S901U ?
    Hotdog453 likes this.
  3. Hotdog453
    Ohio
    2024 Prius Prime
    XSE Premium
    Thanks! I assume the 'dealer', or 'the installer', has to initially synch it up, then it's available in a menu?
  4. Hammersmith
    1,307
    1,334
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Nope. Just have the correct TPMS sensors installed on the wheels, go into the car's menu to tell it to recognize a second set of wheels, then drive around for a bit. No dealer needed.
    SM-S901U ?
  5. Hotdog453
    Ohio
    2024 Prius Prime
    XSE Premium
    Haha! Even better. Thanks.
  6. Zeromus
    Zeromus Member
    352
    166
    Ottawa Canada
    2024 Prius Prime
    SE
    If you have aftermarket TPMS sensors, they'll need to be programmed as recognizable by the car as "toyota" sensors. I mine were programmed directly at first, then when they lost connection I couldn't reconnect them. The tire place fixed it once I explained the issue, they had done a direct program themselves not realizing it wasn't necessary and that the car had the self-register feature.
    Since then, no problems whatsoever.
  7. Hotdog453
    Ohio
    2024 Prius Prime
    XSE Premium
    Nice! Thanks for the info. I'm having the dealer themselves actually do it, but that's a lot better than a lot of OEMs, being able to swap them around like that. Subaru is a pain.
