Winter Question
Discussion in 'Gen 2 Prius Main Forum' started by shamrocks1980, Jan 4, 2007.
  1. shamrocks1980
    shamrocks1980 New Member
    Can you lock a prius from the outside if it is running?
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Yes, you can. The car automatically gives you a tough time if it's running or the fob is in the car - it doesn't want to you accidentally lock yourself out. Anyways, the solution is to use the little metal key in the fob to manually lock the drivers door. I'm pretty sure you'll then also have to use the metal key to unlock it, as well.
  3. shamrocks1980
    I will try that tomorrow morning. :) thanks
