Alternative Spare Tire
Discussion in 'Gen 5 Prius Accessories and Modifications' started by NullDev, Feb 15, 2024.
  1. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    As a new owner of a red 24 Prime XSE, I've really enjoyed reading through all the various threads here trying to get up to speed. Thanks for the awesome resource!
    I commute about 100 miles a day and I personally like to be self sufficient, so I think a spare tire purchase is in my future. To this end, I've read several of the "spare tire" threads here and I've researched both ModernSpare and EZSpare. Both options are a little pricey and in my opinion, each has a couple downsides.
    This took my search a bit off the beaten path and I ran into this on Amazon. It's from a manufacturer I've never heard of (StanceMagic), but it's a 135/80R18 mounted tire with a 5x114.3 bolt pattern. It comes with what looks like the same tools and carry bag as the other more well known options. The 3 differences that I see:
    1. The rim bore is 64.1mm rather than 60.0mm which I don't think is an issue.
    2. The portion of the jack that fits to the car is obviously wrong (meant for a Tesla), but perhaps this can be altered. It's difficult to determine by looking at the pictures.
    3. The rolling diameter is only 0.2" less than the stock XSE tires which is much closer than either of the other options.
    My question is this, what do you all think? Is there something I'm missing that is a red flag?
    EDIT - I can't create links yet, so here's the full name of the Amazon item: "StanceMagic Complete Spare Wheel and Tire Compatible with 2017+ Tesla Model 3 Performance Trim with 20" Wheels - Includes 18x4 Rim, 135/80R18 Tire, Scissor Jack, Tire Iron, Sockets, Carrying Bag"
  2. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    I should have mentioned that it lists the wheel offset as 10mm. I'll need to do some math and figure out if this is an issue or not. It's my first time doing "tire math", so I'm not sure what all the potential issues might be.
  3. Hammersmith
    Hammersmith Senior Member
    2,326
    2,378
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I guess I just don't understand why you want to pay $75 for a bag.
    That kit is $335 for tire, wheel, tools & bag.
    Through Toyota(Lewis Toyota) and TireRack, you can get the wheel, tire, and tool kit meant for your vehicle for $260.
    It's obviously your money to spend, but...
    $97.20 - Yokohama Y870B 145/90D18
    https://www.tirerack.com/tires/tires.jsp?tireMake=Yokohama&tireModel=Y870B&partnum=49MD6YOTEMP&vehicleSearch=false&fromCompare1=yes
    $72.09 - Spare Wheel - 42611-21280
    Wheel | Part #4261121280 | Toyota Auto Parts
    $90.26 - Tool Kit for the Prime - 09105-47020 (seriously overpriced, so maybe find a similar used set on eBay to save even more?)
    Box Set, Jack
    Then all you need is a bag to carry it in.
    Oh, and you'll need to pay to have the tire mounted on the wheel. I think I was charged $10 by a local tire shop; or maybe it was $20. Actually, I think it cost $10 to mount the replacement spare on my old car, but the new car spare cost me $20 because it also needed a valve stem.
    #3 Hammersmith, Feb 15, 2024
    Templeton and tat2boy like this.
  4. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    I originally started down the path of trying to source all the parts individually, but couldn't find the correct rim. This gets me pointed in a better direction. Thank you!
  5. Templeton
    Templeton Active Member
    327
    118
    usa
    2024 Prius Prime
    SE
    Great info, thanks.
    The rim you linked is for a full sized spare, correct? Is there an easy way to find the toyota part number for a rim (or complete wheel) that is a narrower temporary spare with an 5/6/7 spoke aluminum rim that would fit a '24 prius prime SE ? Most important is to find a temporary spare that is identical (or nearly so) in diameter to my stock wheels.
    Thanks for the help.
  6. Hammersmith
    2,326
    2,378
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No, that was for the Toyota donut spare that fits on the Prius. The wheel is a 16x4 and you fit it with a 145/90/16 tire that has a diameter right between the 195/60/17 and 195/50/19 stock sizes. All of the spare wheels(Toyota, Modern Spare, etc.) are typically around 4" wide and mount a 135 or 145 width tire.*
    No spare of any size fits under the cargo floor of the Prius Prime. Any spare you have in the car will have to be above the floor or in the back seats. The regular Prius can fit a donut spare under the cargo floor(easily in the case of the XLE and LTD, with a little modification in the case of the LE), but can't fit a full sized spare.
    * Stock 17" diameter = 26.2"
    Toyota: 16x4 with 145/90/16 = 26.3" (+0.4%)
    Modern Spare: 18x4 with 135/70/18 = 25.4" (-3.1%)
    EZ-Spare (3 choices on their website)
    - 1. 17x5 with 145/80/17 = 26.1" (-0.4%)
    - 2. 17x5 with 165/70/17 = 26.1" (-0.4%)
    - 3. 18x4.5 with 125/80/18 = 25.9" (-1.1%)
    Widths:
    125 = 4.9" (EZ-Spare 3)
    135 = 5.3" (Modern Spare)
    145 = 5.7" (Toyota, EZ-Spare 1)
    165 = 6.5" (EZ-Spare 2)
    You could also put a 135/90/16 on the Toyota wheel to get you 5.3" wide and 25.6"(-2.3%) in diameter
    zare34, Templeton and Jabog6 like this.
  7. Templeton
    327
    118
    usa
    2024 Prius Prime
    SE
    Thanks. But the Toyota spare you linked to is a steel wheel, correct?
  8. Templeton
    327
    118
    usa
    2024 Prius Prime
    SE
    Thanks for the earlier reply. But, a few more questions: why is there a difference regarding fitting a donut spare under the floor in the case of regular prius LE vs under the floor of a regular prius XLE ? Are the vehicles different, or are the spares different? If it is the vehicles that are different, what about them is different that makes the different trims having different amounts of under floor space? Then, regarding trying to fit a donut spare under the floor of the prime, what intrudes in that area to prevent this? Is it the foam that toyota puts there, or is it the traction battery that prevents this?
    #8 Templeton, Jul 5, 2024
  9. purplePriii
    purplePriii Active Member
    275
    122
    I am not sure if you'll know but you seem fairly knowledgeable. Does most spares have the same centre bore? 5th gen should be 60.1mm but I've seen a few other car's spares that would work but in theory their centre bore is 67.1. I'm not sure if there's some standard with spare wheels or you'd need something like hub rings.
    Templeton likes this.
  10. Hammersmith
    2,326
    2,378
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No, spare wheels have many different center bores. The Prius uses one of the smaller bores out there at 60.1mm. The 3rd party spares(ModernSpare, EZ-Spare, etc.) tend to use larger bores so they can fit as many cars as possible.
    If you end up using a wheel with a bore bigger than 60.1mm, you really should use a hubcentric ring with it. If you order from one of the 3rd party companies, the kit should come with the correct ring. If you're sourcing a wheel yourself, you'll need to get the correct one yourself(they're pretty cheap).
    Again, this is one of the reasons I like using the OEM-specced wheel; don't have to worry about any of this. Don't need to worry about hub rings, don't need to worry about different bevel angles on the lug nuts. Just put it on and go.
    Total side note...
    I was checking out some of the FAQ pages at ModernSpare. They were trumpeting how much better their spare was because it was designed to be as close as possible to the OEM tire diameter and that the tire they used had a DOT M rating so it could be driven at highway speeds and for longer distances. There was all this blather about how good their tire was and massive inferences about how bad traditional compact spares were.
    So I looked up the tire they were using. It did, in fact, have a rating of 104M. Then I looked at all the 145/90/16 spare tires that you would use with the OEM Toyota wheel. Every one had a rating of 106M. They were actually rated for the same speeds and even higher weight loads than the one ModernSpare uses. And the OEM spare tire is way closer to the full-size tire diameter than the ModernSpare choice is. The only benefit to the ModernSpare tire is that it's a radial when the 16" tires are all bias-ply. But the 16" tires have the same speed rating and better load ratings, so...
  11. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    ^^ This...
    I was going to get a Tesla spare, but saw the bore was the wrong size and didn't want to fiddle with spacers. Since Toyota rims are hub-centric rather than lug-centric, it was just one more thing to worry about. Once I determined the OEM steel rim and tire were lighter weight than the aftermarket options, it was a no brainer.
    GcinFl and Templeton like this.
  12. Templeton
    327
    118
    usa
    2024 Prius Prime
    SE
    Your info has been great, so thanks!
    A few more questions: is there a toyota branded and/or OEM donut type spare wheel (so not aftermarket) that fits the priusP (not "fits" inside the cabin, but that "fits" as a spare wheel temporary replacement) that has an aluminum alloy rim? and that is hopefully lighter than the steel spare wheels?
    I don't have a priusP (trying to get one now), but has anyone successfully done any mods on, say, a priusP SE trim where they have mounted a suitable donut spare under the cargo floor, but then cut/modified/lifted/etc the cargo floor such that the spare wheel was secure and its intrusion into the cargo area was not crazy big? I looked all over the interwebs but could find nothing (except regular prius spare wheel mods).
    Also, does the priusP that is sold in Japan, does that have a spare? If yes, how is that spare mounted inside the car from the factory?
    Thanks again.
  13. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    For what it's worth, as I mentioned above, I purchased the OEM steel spare rim and 145/90R16 tire. The combined weight was 29 lbs. Compare this to the Modern Spare aftermarket alloy rim and 135/80R18 tire coming in at 39lbs. At this point, if your main concern is weight, get the OEM steel rim.
    Most (maybe all) of the space under the cargo floor in the Prime is taken up with the traction battery and charge circuitry. I currently have my spare in the trunk. If I need the trunk space, I can wedge the spare behind the front passenger or driver seat.
  14. Hammersmith
    2,326
    2,378
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    In no particular order...
    The Prime in Japan can't fit a spare inside either. Other than the dash being flipped, they're basically identical from a structure point of view.
    I don't think Toyota makes a compact wheel made of aluminum/alloy. If they do, I wouldn't know where to start looking. I guess I'd start looking aftermarket and see what turns up.
    Trying to alter the floor of a Prime for a spare is basically a no-go. In the HEV, the sheet metal floor is concave to provide space for the tire. In the Prime, the sheet metal floor is basically convex to allow for extra space underneath for the larger HV battery. A compact spare will generally be about 5.5" thick. The foam deck box in a Prime is only about 2" thick at it's thinnest point(which is where the tire would have to sit). So any tire laying on the floor would protrude at least 3.5" above the floor level, probably more. And there's no way to secure it well.
    Here's a thread by an XSE owner with great photos of all the parts(there's no difference in the cargo area between an SE and XSE):
    2023 Prius Prime | PriusChat
  15. Templeton
    327
    118
    usa
    2024 Prius Prime
    SE
    Interesting, so does that mean that the Japanese market priusP does not come with a spare? just a bottle of the tire repair stuff? Or, if it does come with a spare, where is it stashed on the Japanese version?
    If it helps, we have a rav4P, and it does indeed come with a toyota 5 or 6-spoke aluminum rim space saver spare. I can post a photo of it if that would help.
    Good info about the priusP subfloor, as that all makes sense. Related, has anyone on this forum posted images of what the gen5 priusP looks like under there with the foam all removed? Clearly, doing a mod where I would cut the plastic cargo deck is ok (in my mind at least), but doing a mod where the spare cannot be fully and safely secured would indeed be a no-go.
    Thanks again for all of your help and the previous links.
  16. Templeton
    327
    118
    usa
    2024 Prius Prime
    SE
    Yeah, I don't care about the looks, I just want to see if I could get even lower in weight, like well under 29 lbs. I only assumed that this is possible because our rav4P also has a toyota aluminum spare wheel (space saver variety).
  17. Hammersmith
    2,326
    2,378
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    If you click on the link in my last post, it takes you to a thread with all the pictures you need.
    No Japanese Priuses come with spares as standard equipment. The HEV Priuses can be ordered with a spare as an option, but the PHEV(Prime) cannot.
    If the RAV4 Prime spare wheel is aluminum and you're going for minimum weight, you could just go with it and fit it with a 135/80-17 or 135/90-17. The RAV4 wheel(17x4T) will fit on the Prius, and those tire sizes will match the stock 17" circumference within 3%. If you want a little more tread width, you could also do 145/80-17.
  18. Templeton
    327
    118
    usa
    2024 Prius Prime
    SE
    Thanks for that link, exactly what I wanted. I have no idea how I missed it.
    Yes, our rav4P spare is 17" and has a 165/80R17 tire installed stock. I haven't looked up the actual rim width or offset. Not even sure if its lighter than the steel rim you linked earlier. That said, here is a (partial) photo for those that might be interested:
  19. Hammersmith
    2,326
    2,378
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I checked the RAV4 Prime owners manual before I posted. The spare wheel is listed as either a 17x4T or 18x4T. Since you have the 17" spare, that must mean you have an SE. And if you're minimizing weight, you want less wheel and more tire. I also checked wheel-size.com for the technical info on the RAV4 Prime wheel, which is a 5x114.3 bolt spacing and 60.1mm center bore no matter the trim. I don't think offset matters that much for a spare wheel. So all that should mean any wheel for a RAV4 Prime will physically work on any gen5 Prius.
    The bad news: The OEM aluminum spare wheel for the RAV4 Prime(42611-33E70) has an MSRP of $403.84(vs. the MSRP of the steel Prius wheel of $104.28). Real world pricing of anything from $65(salvage) to $280(new) for the aluminum RAV4 wheel, and $45(salvage) to $72(new) for the steel Prius wheel.
    New: 42611-33E70(17x4 aluminum) and 42611-21280(16x4 steel) using Lewis Toyota
    Used: search car-part.com for a RAV4 aluminum wheel or a C-HR steel(it's the same wheel as the Prius)
  20. Templeton
    327
    118
    usa
    2024 Prius Prime
    SE
    Thanks again for all of that info. Yes, we have an rav4P SE.
    And, agreed, $400 for a spare wheel is indeed steep. Sounds like steel is the way to go ... !
