2006 ABS Actuator - pump replacement not whole assembly
Discussion in 'Gen 2 Prius Technical Discussion' started by BluePrius2gen, Jul 5, 2024 at 5:12 PM.
  1. BluePrius2gen
    BluePrius2gen Junior Member
    philadelphia
    Has anyone replaced just the pump on the ABS actuator assembly. I found the part on Aliexpress and ebay for about $150 (vs$1200 for the whole OEM assembly).
    Is the leak usually coming from the pump motor or anywhere else on the assembly (hoses tank etc.)?
    2006 Prius 270k
    oem actuator part 44500-47140
    The listing on aliexpress:
    Automobile ABS Brake Pump Motor For Toyota Prius 2004-2009 44510-47050 4450047140 Prius Parts
    Any ideas?
