Passenger footwell leak, oil?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Caldude805, Jul 5, 2024.
  1. Caldude805
    Caldude805 Junior Member
    On the passenger side footwell my Prius there is a very slow leak. It’s coming from almost this exact spot in this video but in the video it’s clearly water, in my car the fluid is more orange and looks and feels like oil. Kinda smells like it too but I can’t be 100%.
    Anyone else run into this strange oily leak too?
  2. Tombukt2
    13,477
    2,422
    Orange red usually indicates coolant The drain from the air conditioner generally will be just clear water.
  3. Caldude805
    Okay, I’ll try to look up cooland leaks for that area.
  4. Tombukt2
    13,477
    2,422
    Pretty much I think the only thing you're going to find in that area is a heater core that's inside the box with the AC evaporator would have to be a pretty good size leak to fill up that box and get to the floor maybe somebody just spilled some Fanta
  5. Rheedal
    Rheedal New Member
    China
    You can check the power cell, coolant, and transmission fluid to see where the leak is occurring.
  6. Tombukt2
    13,477
    2,422
    Put your finger in the leak and bring your finger to your nose what do you smell coolant is distinctive oil is pretty distinctive how it's going to get on the floor of the car not likely. So again your choices are water from the condensate drain of the AC which is possible and it used to be if your heater core had a leak You could get same red Asian coolant on the floor I'm not sure if this can happen in the Prius or not they've changed a lot of these heater core locations and things around so that the core stays closer to the firewall and the connections are actually kind of sticking through the firewall and if the thing leaks it'll run down the firewall more than it will in the car so there should be a smell if it's serious if it's condensate drain it's not really that serious it doesn't do well to keep your car cool so you may want to run a small plastic rod through the firewall penetrating drain hole and when you pull the little rod out there's a whole bunch of water come out You just found your problem probably.
