Roommate's Car - C1343
Discussion in 'Gen 2 Prius Technical Discussion' started by KitsuneVoss, Jun 30, 2024 at 10:12 AM.
  1. ChapmanF
    15,489
    If I remember right, Hybrid Pit Stop may have advertised a rebuilding service for gen 3 brake actuators (if without seeming very forthcoming about what they actually do).
    I don't know whether they offer anything similar for gen 2.
  2. KitsuneVoss
    KitsuneVoss Member
    140
    28
    Virginia
    Something strange, not with my car but with a coworker. He is driving his sister's 2005 Toyota mini-van. Been driving it because it has AC and his does not. It has a more traditional; dash. It has all the same lights lit even though a more traditional dash with dials and gauges. VSC, TRAC, and ABS. Makes me wonder how many people arr driving around with those gauges lit. I told him I would bring my testing laptop to work and check out the codes next week.
  3. Tombukt2
    8,944
    1,557
    That should be a sienna van I guess yes it'll have very similar lights usually in the sienna van with lighten up the check engine light is the evap relay near the gas tank in the back and I'm not sure about the ABS and the VSC in the traction control you have all that in this model van so it must be a symphony dual sunroof so on and so forth type setup or actually '05 that'll be after the symphony I don't know what that trim level would be called
  4. ChapmanF
    15,489
