Newbie battery question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Martinf, Jul 7, 2024 at 3:45 PM.
  1. Martinf
    Martinf New Member
    Chelan, wa
    SE
    I'm a subaru mechanic, but don't know much about prius. My daughter has a 2008 with a dead 12v from leaving a door ajar. Known good battery (I replaced it 3 months ago).
    My questions pertains to a jump start. I know where the pads are under the hood, so she can jump it. No problem there.
    If it were a subaru, I'd tell her to just go for a 30 min drive after the jump and she'd be good. But, what about the prius? If she's going in stop and go traffic, which she will have to, won't the engine be stopping and then need to restart, but the 12v battery won't have enough charge and she'll be stuck again?
    Or, if she just stays in the parking lot where she's getting jumped, will the engine keep running (after the jump) to charge the 12v battery?
    She doesn't have access to a trickle charger and there's no 120 v access out there in the parking lot and I'm across the state. And I doubt she could pull the 12v and bring it inside.
    Get my situation and the jist of my question? Thanks for any insight here!
    ~martin
  2. Tideland Prius
    16,128
    If you run it in "B" mode (instead of Drive), the engine won't shut down at a stop so you can use that technique to keep the engine running to keep the 12V charged during the drive after a jump.
    Note that the engine may seem like it's stuttering because the computer is trying to shut it off but the parameters of B mode won't let it shut down.
  3. Brian1954
    Brian1954 Active Member
    807
    300
    South Central PA, USA
    The internal combustion engine does not need to be running to charge the 12v battery. The Prius does not have an alternator. The 12v battery is charged from the hybrid battery by the dc/dc conveter whenever the car is in ready mode and the car is in park or drive. But it will take many hours for the car to fully charge the 12v battery. It is best to fully charge the 12v battery by using a charger.
  4. bisco
    49,401
    if there is a safe place, she can leave the car 'ready' in park for about 8 hours and the battery should get a good charge.
  5. Martinf
    Martinf New Member
    Chelan, wa
    SE
    Wow, am I learning something here! Alright, no alternator...
    So how does my daughter get it in "ready" mode? (To then do the slow charge from the hv batteries to the 12v)
    She says that nothing comes on or lights up or anything. She had to use the manual key to unlock the door cauae the key fob wouldn't work.
    Thanks for all the help, folks
  6. dolj
    dolj Senior Member
    7,634
    3,851
    Wellington, New Zealand
    READY mode is when the word "READY" lights up on the dash. It is the state you get into that allows you to drive the car. You get to READY with a single press of the power button with your foot on the brake. If the battery was totally flat (so she had a completely no power situation just like disconnecting the 12 V battery), she will need to press the power button twice for that first start. In this scenario, the first press of the power button will go into an IG-ON state (usually attained by pressing the power button twice with your foot off the brake) so lighting all the warning lights, then the second press moves it to READY.
    I'm sorry about the long explanation but the two-button press catches a lot of people out.
    I hope that helps.
