Prius Prime 2017 not getting 621 miles on gas.
Discussion in 'Prime Fuel Economy & EV Range' started by HaiJinx, Jul 8, 2024.
  1. HaiJinx
    HaiJinx Junior Member
    Los Angeles
    When I fill up my tank it says I have 433 miles remaining. And it’s pretty accurate. Why does (image attached) Toyota claim I can get 55 MPG?
  2. dbstoo
    dbstoo Senior Member
    1,384
    748
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    In general, the Prius Prime 2017 is designed such that the fuel gauge will tell you that the car's gas tank is empty when you actually have about 3 gallons of gas left.
    BiomedO1 likes this.
  3. BiomedO1
    3,141
    1,665
    SacTown, Ca
    It's a guess-o-meter based on your driving style.
    I'm guessing you rarely plug the car in, you do short hops, your not driving in ECO mode and you've got a low eco score. If your doing short hops, best to run the car in EV mode. I plug-in everyday, drive 50-50 mix of highway/city and I'm getting 1.1K-1.3K per tank. Last calculated fill-up was 112 mpg. Odometer read 119 mpg. The EV usage accounts for a lot of your mpg savings. Your still getting around 40 mpg, I'm assuming your pumping in 11 gallons on a fill-up. What did you get on the last ICE only car you've driven? I bet that car performed below EPA standards too.
    On your next fill-up, try dividing the number of gallons you put into the tank by the number of miles you've driven on that tank to get a 'true' reading.
    Hope this helps
    #3 BiomedO1, Jul 8, 2024
  4. bisco
    51,525
    it's not a toyota claim, it's an epa test. if your car is in good condition, it will get that when you run the test. YMMV
  5. BiomedO1
    3,141
    1,665
    SacTown, Ca
    Also forgot to mention; you may be putting really crappy gas into the tank if your always going to the same gas station. Very high ethanol content- or watered down- gas will require more gas for the equivalent number of miles. Lower energy content. Modern ECU driven engines will automatically compensate for crappy gas, varying timing and mixture, unlike old school carburetor engines.
  6. Mr.Vanvandenburg
    1,344
    559
    2020 Prius Prime
    Not one problem with gas, water in it, and other things, since 10% alcohol. Decades now I guess. Before 10%, did have problems
  7. bisco
    51,525
    speeding will decrease the mpg's
