GEN 1 prius P3106 powertrain code and vehicle stalls
Discussion in 'Generation 1 Prius Discussion' started by blake9809, Jul 8, 2024.
  1. blake9809
    blake9809 Junior Member
    48
    Minneapolis, Minnesota
    2002 Prius
    SE
    I have a gen 1 prius 2002, was a good running vehicle with no codes other than a o2 sensor code because the cat was stolen. Car was running like a prius should, i parked the vehicle for 9 days and came home turned the key and the gasoline engine turns over, fires and runs for 10 seconds then stalls out. On the dash the fuel gauge blinks full then empty, full then empty continuously, the outside temp displays E, the HV battery gauge on dash displays empty. I then checked voltage of HV battery and its 303V, i then checked voltage of 12v battery and it reads 12.6v. When i scan for codes the only code that comes up is a P3106 code and all i know about the code is its a powertrain code.
    Can someone guide me on where to even start to diagnose or fix this issue.
  2. ChapmanF
    19,041
    P3106 involves communication between the HV ECU (kind of the orchestra conductor for the car) and the ECM (which controls the engine). I would expect weird results if those two aren't getting along.
    There are some three-digit INF codes you can get with P3106, by looking in the code's "freeze frame" (using a scan tool that can do that).
    if the INF code is 209, 210, or 211, the manual says to check the actual comm wiring (pin 28 of connector H14 at the HV ECU to pin 28 of connector E9 at the ECM, and pin 27 of H14 to pin 27 of E9), and if a wiring fault isn't found, to replace the ECM.
    If the INF code is 212, it's not so much the communication circuit as what was communicated. The ECM said "something is wrong" and the HV ECU heard it just fine. Manual suggests saving the current HV ECU codes and freeze frames, clearing codes, and proceeding with troubleshooting of any DTCs the ECM itself might be reporting.
    If the INF code is 394, the ECM seems to be asleep on the job. Check the circuit(s) bringing power to the ECM (after first saving codes and freeze frames and clearing, as above). If no problem is found with power to the ECM, replace the ECM.
    The repair manual and the wiring diagrams (to consult for some of the electrical tests above) can be accessed as described here:
    Toyota Service Information and Where To Find It | PriusChat
    As for the blinking fuel gauge segments, see this post. (It summarizes "fuel gauge diagnosis check" under "diagnosis - combination meter system" in the repair manual, so if you get access to the repair manual, the information is all there.)
    #2 ChapmanF, Jul 8, 2024
  3. blake9809
    48
    2002 Prius
    SE
    When you refer to replace the ECM are you suggesting the ECM behind the glove box on passenger side dash?
  4. ChapmanF
    19,041
    There's only one ECM in the car. There are several ECUs (ECU is the generic term, electronic control unit) but only one of those is the Engine Control Module. Yes, it's behind the glove box.
    ECUs are made of silicon and go bad about as often as rocks do, so I probably wouldn't just replace it unless I had done the other troubleshooting and that's what was left.
  5. blake9809
    48
    2002 Prius
    SE
    ok very well thank you for all the great info, i have a ECM laying around i will swap the ECM out since that should be fairly simple. If i get all the same issues i will proceed with diagnosing further.
  6. blake9809
    48
    2002 Prius
    SE
    I swapped out the ECM and no change in symptoms. Is it possible a bad fuse or relay could be causing this issue?
  7. ChapmanF
    19,041
    I'd be more inclined to suspect wiring. But to avoid spending extra time and money, it pays to get access to a scan tool that can pull the P3106 INF code, and then follow the repair manual troubleshooting steps from there.
  8. ronlewis
    ronlewis Active Member
    1,061
    206
    texas
    2001 Prius
    I have an electrical and repair manuals on PDF if you want copies.
  9. blake9809
    48
    2002 Prius
    SE
    yes please, that would be very helpful and appreciated. I have so much time invested in this car replacing the gas engine and hybrid battery it would be a shame to not have this gen 1 up and running again. It ran great no issue for about a year. Now this...
  10. ronlewis
    1,061
    206
    texas
    2001 Prius
    Give me an email address. I'm in Houston and the hurricane has power and internet messed up. I found electricity at a nursing home and their internet is working, but I can't stay here for long, lol.
  11. blake9809
    48
    2002 Prius
    SE
    Hopefully not much storm damage for you. I messaged you my email
  12. blake9809
    48
    2002 Prius
    SE
    could this issue be caused by a bad fuse or relay? i am going to check all fuses next
  13. ChapmanF
    19,041
    Never say never, but I expect you'll have a solution faster by following the troubleshooting in the repair manual.
  14. blake9809
    48
    2002 Prius
    SE
    do you have repair manual copy or what repair manual do you suggest following? where do i get or buy this?
  15. ChapmanF
    19,041
  16. Bruce Berquist
    Bruce Berquist Junior Member
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    You need to reevaluate the 12v battery and 12v system and all connections and terminals. The 12.6v reading is a healthy voltage but it does not mean that the battery and 12v power signal to the ECU syatem is actually healthy and adequate for booting up the sytem to operate properly.
    I am quite certain that you are going to resist what I tell you, but I recommend that you give it a try, regardless.
    What voltage does the 12v battery have when under the load of ignition starting position?
    That is... with the ignition in the starting position, but without starting the engine.
    If the voltage is under 12.2 volts, you are booting the system with inadequate voltage.
    For the Prius system, this 12v battery test is more important than any other type of load test typically given for ICE vehicle batteries. Two very different animals with two very different needs and requirements for the 12v battery.
    If under 12.2 v you need to install a fresh new 46ah+ battery (not just a CCA based battery).
    The process of "jumping" will most times be inadequate also, since you are passing the signal through the faulty battery.
    A complete disconnect of the old battery, then a solid reconnect of a good battery is what is needed, and this will also hard reset the ECU system for clean recalibration.
    Try it (in this exact way). You might like it.
  17. Trombone
    Trombone Active Member
    389
    130
    Allentown, Pennsylvania
    2002 Prius
    My 2002 has four ignition switch positions: Lock, Acc, On, Start. My voltage readings on the ScanGaugeII are: Lock, 12.2; Acc, 12.1; On, 11.8 (readings taken with all lights and accessories off). Start is a spring-loaded position; user must turn and hold key in Start and the ICE will start (duh!). Key will not stay in Start position on its own; key reverts to On when released from Start.
    OP has solved the problem, and it wasn't the 12V battery . Based on my experience, his voltages seem to be OK.
    Bruce Berquist likes this.
  18. Bruce Berquist
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    11,8v in "on" position is insufficient for booting up the ECU system properly. 12.2v in the "on" position (the position before you hit the starter) is the minimum requirement.
    Best fix is a good NEW 46ah+ AGM battery.
  19. Trombone
    389
    130
    2002 Prius
    Don’t need a fix, don’t have a problem. My car starts and runs just fine. Point is, arbitrary pronouncements must give way to observed results. YMMV.
  20. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    I'm just wondering how you've come to this conclusion since it is not my experience. Is the Gen 1 more fragile electrically speaking?
