Prius Prime 2017 not getting 621 miles on gas.
Discussion in 'Prime Fuel Economy & EV Range' started by HaiJinx, Jul 8, 2024 at 2:18 AM.
  1. HaiJinx
    HaiJinx Junior Member
    Los Angeles
    When I fill up my tank it says I have 433 miles remaining. And it’s pretty accurate. Why does (image attached) Toyota claim I can get 55 MPG?
  2. dbstoo
    dbstoo Senior Member
    1,325
    701
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    In general, the Prius Prime 2017 is designed such that the fuel gauge will tell you that the car's gas tank is empty when you actually have about 3 gallons of gas left.
    BiomedO1 likes this.
  3. BiomedO1
    1,447
    790
    SacTown, Ca
    It's a guess-o-meter based on your driving style.
    I'm guessing you rarely plug the car in, you do short hops, your not driving in ECO mode and you've got a low eco score. If your doing short hops, best to run the car in EV mode. I plug-in everyday, drive 50-50 mix of highway/city and I'm getting 1.1K-1.3K per tank. Last calculated fill-up was 112 mpg. Odometer read 119 mpg. The EV usage accounts for a lot of your mpg savings. Your still getting around 40 mpg, I'm assuming your pumping in 11 gallons on a fill-up. What did you get on the last ICE only car you've driven? I bet that car performed below EPA standards too.
    On your next fill-up, try dividing the number of gallons you put into the tank by the number of miles you've driven on that tank to get a 'true' reading.
    Hope this helps
    #3 BiomedO1, Jul 8, 2024 at 10:50 AM
  4. bisco
    49,402
    it's not a toyota claim, it's an epa test. if your car is in good condition, it will get that when you run the test. YMMV
