B1442 Air inlet damper control servomotor circuit
Discussion in 'Gen 2 Prius Main Forum' started by flyboy09, Oct 17, 2018.
  1. flyboy09
    flyboy09 Junior Member
    Seymour Tennessee
    i do not have a handheld tester for inspection...most of the testing results in replacing the air conditioning amplifier...one test result calls for replace of air inlet control servomotor. Is there a pattern of this code showing the failure of one result over the other or an easy fix?
  2. flyboy09
    Seymour Tennessee
  3. PriusCamper
    PriusCamper Senior Member
    12,293
    4,991
    Pacific Northwest, USA
    This is the code from the head unit? Or from an OBD2 reading device?
  4. flyboy09
    Seymour Tennessee
    techstream software via obd2 cable connection.
  5. ChapmanF
    17,705
    Anything the manual says you could do with the old handheld tester, you can do with Techstream.
  6. PriusCamper
    12,293
    4,991
    Maybe try some of these comments I dug up?
    and
  7. flyboy09
    Seymour Tennessee
    techstream was able to show data but i am not able to interpret the results...i cleaned out the blower area,change the cabin filter and cleared the code... will drive tomorrow and recheck for codes the day after...do you think the nest in the blower area could have set off the code? IMG_5003.jpg
  8. PriusCamper
    12,293
    4,991
    It's possible... Did you know you're suppose to replace the filter every 6 months? Lol... That's so much material I'd reccomend using lots of specialized vacuum cleaner attachments to stick up into as many of the venting places as possible. Other concern is inspecting for worst case scenario, which is that they like the taste of your wires.
  9. flyboy09
    Seymour Tennessee
    just wondering if there is a way to install some type of barrier, like a screen, to keep these critters from entering?
  10. ChapmanF
    17,705
    There are threads here about doing exactly that. Not sure the fastest way to search them up. If I remember right, @cyberpriusII has experience in that department, might look for some of her threads.
    -Chap
    SFO likes this.
  11. PriusCamper
    12,293
    4,991
    Creating a barrier is possible... But if you always keep a clean empty car and change this filter every six months like you're supposed to the car will make a far less hospitable place for rodents to live.
    I've seen it on here again and again... People live like slobs and never clean out their half-finished snacks, especially sunflower seeds and nuts ask how they can keep the rodents out. Truth is the rodents are not the problem, just the symptom of a person who doesn't know how to take good care of their car by keeping it clean and empty.
    Solman636 likes this.
  12. Patrick Wong
    18,200
    6,497
    Considering the extreme amount of debris that was sitting on the cabin air filter, I think it is reasonable for you to expect that some of that debris got past the filter and is blocking the "door" that allows fresh air to enter the cabin, or recirculation to occur.
    If you consult the factory repair manual, it will show you how to exercise the door using Techstream. If you find that the door does not move, I would suggest that you first consider how to get to that motor, remove it, and clear any debris. You may be able to get to, and remove the motor after removing the black plastic dashboard assembly. If not, you would have to further disassemble the dashboard to get to the air conditioner evaporator/blower assembly and remove the whole unit. That latter activity is not going to be simple or fun.
  13. flyboy09
    Seymour Tennessee
  14. flyboy09
    Seymour Tennessee
    techstream health check this morning....no codes at all...headed for home depot... screen purchase in my future.
  15. Patrick Wong
    18,200
    6,497
    Have you tried opening and closing the fresh vs. recirculate door to make sure it operates freely?
  16. Newstarr
    Newstarr New Member
    Bay Area, California
    how do you do this?
  17. Patrick Wong
    18,200
    6,497
    By using the MFD control to switch between fresh vs. recirculated air.
  18. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    After pressing the physical "climate" button on the left side of the MFD screen, look for the fresh air/recirculate toggle in the lower right corner of the MFD screen, right next to the Auto toggle.
    Skibob, Raytheeagle and Patrick Wong like this.
  19. Lone_Cricket212
    Lone_Cricket212 Junior Member
    New York
    Were you able to resolve this issue? I have the same code on my Prius.
