2010 Prius , Traction Light ON after changing the Brake Light Sensor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tom Mayor, Jul 10, 2024.
  1. Tom Mayor
    Tom Mayor Junior Member
    55
    Orlando
    Hello,
    I have replaced my brake light switch to correct the issue I had with the car that won't be in Ready Mode, it was actually the STOP fuse. Since then, I have the traction light on constantly, ONLY, not flashing, I don't have any beep noises, I don't have any other lights. I didn't drive after changing brake light and fuse and it still came on while the car was parked. It's been like 500 miles and the light is still on. I unplugged the 12v battery and also put the car in maintenance mode but didn't erase the code. I've checked some ABS fuses but didn't find any that was blown. I didn't drive in rain, mud, snow condition as well. The light came right after I swapped the brake light switch...
    Any idea of what's going on?
    Thanks!
  2. ChapmanF
    18,314
  3. Tombukt2
    13,116
    2,354
    And this was a new switch from the dealer You put in yourself or a switch from a car that kind of look like yours that you pulled from wherever? Yeah try to get codes. If you're going to own a Prius you might want to look into a AP200 scanner It's only about 56 bucks or so be one of the better things you purchase for a Toyota vehicle no subscription one time fee and use.
  4. Tom Mayor
    55
    Orlando
    I don't have any code showing with my both OBDII scanners...
  5. Tom Mayor
    55
    Orlando
    i have 2 OBDII scanners and none of them detected any code... I also just put back the original brake light switch (that came with the car I think) since the issue was due to the fuse. I still have the TRAC light :( .
  6. Tombukt2
    13,116
    2,354
    Well like the fellas at above A lot of code scanners don't read all the codes in the Prius properly It's a tricky situation You need to get hold of a scanner that you can use or whatever that will at least get the brake codes from your Prius I don't think that light can be on with just absolutely no codes but maybe it's possible I would think not I know in my Prius anytime traction control light or any of those orange lights are on I generally have codes pertaining to ABS VSC traction control in general of course I have a very accurate scanner several of them that can read the codes in a Prius and I've dealt with scanners that cannot I have a few over here on the shelf that don't get used on Prius but everything else pretty much so there's always that I'm going to guess you have some kind of off-the-shelf scanner from the big box stores If you didn't pay over $200 for it there's a good chance or almost a guaranteed chance it's not doing what you need it to do.
  7. bisco
    52,091
  8. ChapmanF
    18,314
  9. Tom Mayor
    55
    Orlando
    I plugged a wire and the traction light blinked 6 and 4 times, here's what it should be ... As mentioned I replaced the brake (stop) light switch but didn't solve my issue because it was due to the STOP fuse. I actually put the original back one today to see if the light came on because I put a "china" part ... I may try to disconnect the 12v battery for a bit and see if it solves the issue . I doubt it though ....
  10. Tombukt2
    13,116
    2,354
    Well with those codes it can be your relay and or your skid control ECU and/or your brake booster and the brake boosters common to go on this model.
  11. ChapmanF
    18,314
    Those kinds of reader's-digest trouble-code cheat sheets give you such inadequate information they'll pretty much never help you troubleshoot a problem (and it's not much more help if someone basically reads you the list of possible components at fault from the reader's-digest thing you already found).
    The circuits of interest, involving the stop light switch, the "stop light control relay" (which is more of an interesting electronic thing, not an actual relay), and the brake ECU (which is part of the master cylinder/booster) looks like this:
    You can see how the stop light switch is an input to the 'relay' (at pin 5), but it's also an input to the ECU (pin 33, "STP"). Also, the output of the relay (pin 1) goes to the brake lights, but also to the ECU (pin 6, "STP2"). So the ECU knows when the relay is getting an input to turn on, and the ECU can also tell whether the relay did turn on. Big Brother is watching.
    Also, the ECU can light the brake lights for its own reasons (using its "STP0" output, pin 3, to pin 9 of the 'relay'). Again, it can see on STP2 whether that worked and the relay turned on.
    With that background, you can look at what the codes tell you:
    As you can see, C1380-761 is given when the ECU tried to light the brake lights for its own reasons, but did not see the relay output confirmed on STP2. C1380-762 is given when the ECU is not trying to light the brake lights for its own reasons, but it notices its STP and STP2 inputs do not match: either the stop switch is ON but STP2 is OFF, or STP2 is ON for some reason when the stop switch (or at least the STP input) appears OFF.
    The blink method only gives you the basic code; only a scan tool can also get the 3-digit INF code. Because of your recent work on the switch, I'd probably assume you have 762 here, but if you could check with a scan tool then we'd know for sure.
    My guess would be something pretty simple happened while you were replacing the switch, and by knowing what this code is telling you, you'll be able to find it and straighten it out. There are seven pages of troubleshooting advice in the C1380 section of the repair manual (where I cribbed the information above) if that would help.
    Toyota Service Information and Where To Find It | PriusChat
  12. rjparker
    10,237
    6,390
    Readers Digest repair codes?
    Big Brother is watching?
    I suspect those references escape most of the crowd.
    Tombukt2 likes this.
  13. Tombukt2
    13,116
    2,354
    So what do we think happened here Just replacing the stoplight switch Nick the wire cut a wire left something unplugged?
  14. Tom Mayor
    55
    Orlando
    Thanks for all of these incredible and precious info ! I watched a video of a guy explaining how to reset the dash light and with the paper pin in the port 4 and 13 and the car on I have pressed 8 times the brake pedal (or more) and the Traction Light disappeared :D I hope it will last! Probably a little electronic issue! Here's the part of the video where he's explaining the issue
  15. ChapmanF
    18,314
    That video doesn't explain any issue, it just shows how to use the jumper+pedal strokes alternative to using a scan tool to clear brake system codes. "The" issue he started with (a wheel speed sensor left out of place) was different from "the" issue you had (mismatched STP and STP2 inputs about the brake lights). The only thing "the" two issues have in common is that clearing the code makes the code go away. If you were using a scan tool, its clear-code feature would do the same.
    So you had a C1380 and cleared it, and so far it hasn't come back. As long as it doesn't come back, it may have been set by something that just occurred while you were doing the work, and things are now ok. If it does come back, you'll know from #11 how to troubleshoot it.
  16. Tombukt2
    13,116
    2,354
    That's what I figured The kid doesn't have a scan tool or the one he has is for the Chevrolet etc and I don't know how he figured this out here but whatever seems like a lot of effort for just getting a scan tool for a minute maybe clean off the ends of your wheel sensors they're magnetic crap bills up on them Little things like that A lot of people don't do any housekeeping when they're working on the car they just leave the cake to grease and all the garbage sitting there and then wonder.
