No ready light, no start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Keeley, Oct 27, 2017.
  1. Lib
    Lib Junior Member
    27
    Zambia
  2. Patrick Wong
    18,200
    6,493
    This is a big problem. The traction battery has a high voltage ground fault. You should not be able to measure voltage from either battery cable to body ground. The fact that you can measure this shows that some of the modules have leaked electrolyte which causes the ground fault to the battery case.
    The car probably has at least one other issue besides the high voltage ground fault, since after the 12V battery is disconnected and reconnected, you should be able to start the Prius once if the only issue was the ground fault.
    For example it is likely that at least one battery module has failed. This is evidenced by your voltage measurement not being in a multiple of ~7.2V.
    The 28V measurement probably comes from four modules and is plausible. However the 33V measurement probably comes from five modules, and shows that two or three cells are dead (1.2V each). Or those modules are substantially drained compared to the other sample of four modules.
    Imbalance between module pairs would be another reason for the car not to start. The traction battery ECU tracks voltage of module pairs. If the difference is greater than 0.2V the ECU will log a fault and not allow the car to start. If the battery were operated in that condition, a module may overheat and catch on fire.
    Get Toyota Techstream software (Mini VCI) so that you can retrieve the diagnostic trouble codes.
    #62 Patrick Wong, Jul 27, 2019
    Lib, SFO and jerrymildred like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Thanks, @Patrick Wong! I knew you'd be able to get this going in the right directions. I appreciate your knowledge and helpfulness.
    SFO likes this.
  4. Lib
    Lib Junior Member
    27
    Zambia
    Scanned with LAUNCH and got these codes P0aa4,P0aa1,P3030,P0a0d,P3000,C1241,C1242,C1249,C1259,C1310,C1313,C1353,C1354,C1377,C1378,B1800,B1801,B1810,B1811,B1421,B1433,B1200,B1269,B1271.l later discovered that the Switch on main relay/HV battery was swinged IN but the handle not pressed/locked down .l press down and started the car Wala! Ready came ON and engine run.l scanned while engine was running only three fault codes remains P3000,C1259 and C1310.
    SFO likes this.
  5. Jim Cavanagh
    Jim Cavanagh New Member
    Kansas City, MOo
    Sort of sx
    Me problem. 12v. Checked ok. Hybrid battery came from Best Hybrid Battery in April. Surgery kept me from installing it until now. Panel lights. No Ready. No other noises.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,980
    1,926
    NJ-USA
    First thing I would do is to double check that the orange safety plug is correctly installed. There's 3 steps: Push it in. Flip the lever. Slide the lever down.
    Then you have to press the power button twice if you had the 12V disconnected.
    Otherwise you need to check all of the ecu's for trouble codes. Here's a thread that reviews several apps and devices for smartphones. Several can scan all systems on a Gen2 Prius. (the Autel AP200 has good function for cost)
    https://priuschat.com/index.php?posts/3290690 Screenshot_20230108-154956.jpeg
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    If the car has been sitting since April, I would double check the 12v battery also. Even a brand new 12v battery in a Gen 2 would be near it's limits to survive that long. A 'rebuilt' HV battery, sitting for that long likely has a couple discharged modules also. There's a reason most rebuild companies void their warranty if the car/battery sits unused for 30 days or more.
  8. Warwagoness
    Warwagoness Junior Member
    Colorado
    Two Eco
    I just had the same issues with my 2016. After recharging my battery everything came on fine except the 'ready' light. I simply disconnected the negative post on my 12v battery waited a couple minutes. Reconnected it. This reset the system. It fired like a champ . I hope you get back on the road soon- Blessings to you Keeley
