Noise level and insulation
Discussion in 'Gen 5 Prius Main Forum' started by douglasjre, Jul 12, 2024.
  1. douglasjre
    douglasjre Senior Member
    2,188
    722
    Null, NL
    Anybody have any data on the noise levels of the different Prius prime models as well as the differences in insulation between them?
  2. KMO
    KMO Senior Member
    1,968
    696
    Finland
    2023 Prius Prime
    I've not seen comparative noise measurements between trims, but the top build variant (XSE Premium in USA, or top two trims in Europe) does have a bit more sound insulation. Differences I'm aware of are laminated front side windows, and some better between-engine-and-dash insulation.
    A previous short thread on it here:
    The question of sound deadening insulation throughout the range | PriusChat
  3. PhoS
    PhoS Active Member
    255
    209
    Nowhere
    2023 Prius
    Limited AWD-e
    Not fooling me, if there is more deadening in the Limited it's still not enough. I don't find the engine noise to be particularly loud , my main complaint is the road noise by far. The sound comes from the footwells and doors. I will be focusing my deadening efforts to those areas.
  4. Blackat
    Blackat Active Member
    461
    320
    Colorado
    2023 Prius
    Limited AWD-e
    Exactly. Since I changed tires from the garbage Toyos it's been quieter.
    I plan on doing some sound deadening myself......after I take care of the spare tire storage in the back
