Rear bumper tab reinforcement bracket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HKz, Apr 19, 2024.
  1. HKz
    HKz Junior Member
    45
    17
    Mesa, AZ
    Hi folks,
    Still getting around to installing a replacement blend door servo with my other thread but in the meantime, I got one of those metal brackets to fix our rear bumper which for the past couple years had some ripped tabs since some a-hole hit us while parked and didn't leave any insurance info -.-
    Very easy to install, rear bumper removal is a cakewalk and the pieces do a great job with making fitment virtually perfect again. I notice a ton of 3rd gen Prius around with sagging rear bumpers and this seems to be a good fix. Anyone with basic fabrication skills could easily duplicate the results themselves without paying $15 on ebay like I did.
    Screenshot_20240418_221029_eBay.jpg 20240405_132635_resized.jpg 20220528_114418_resized (1).jpg
    After:
    Burna J and Xterra72 like this.
  2. Raceteker
    Raceteker New Member
    Long Island, NY
    Can you tell me where you found the kit for $15? I've been looking every so often, but they're always $45+. I've already attempted to make my own too many times. This kit seems to be the perfect thickness, size, etc. Thanks!
    Burna J likes this.
  3. Mendel Leisk
    41,798
    I tried to cobble those pieces, using galvanized steel gauge plate (readily available hanger/tie strap); it proved ill-fitting, maybe too thick of a gauge plate. I’d appreciate if someone who bought the commercial version could post the dimensions, both overall and plate thickness, the latter measured with a micrometer or caliper.
  4. HKz
    HKz Junior Member
    45
    17
    Mesa, AZ
    Hey raceteker I apologize, looks like it was closer to $25 when I got them. If you have random sheet metal laying around, you can cut it out and hammer it to be the perfect shape should be perfect.
    Yea stuff was really thin but not thin enough where breathing on it did not bend it...sadly did not take any measurements beforehand and neither did the paperwork say anything. But I suspect left over sheet metal from most any car would be perfect
  5. Burna J
    1,071
    3,340
    53
    Long Beach, CA.
    Here the thickness I use.. 304 SS
    Call Hybrid Pit.. I just dropped some sets off last month. (y)
  6. Mendel Leisk
    41,798
    I’m looking at an inch caliper, showing 0.023” thickness, maybe 24 gauge? Looks very thin; I’m thinking it has to be, and mine are way too thick.
    thanks!
    addendum:
    I make 0.23” is roughly 0.5 mm. My cobbled one measures 1.3 mm. :(
    #6 Mendel Leisk, Jul 14, 2024
    Burna J likes this.
