B1423 faulty sensor?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Carsten, Jul 12, 2024.
  1. Carsten
    Carsten Junior Member
    60
    Columbia, SC
    Hi all,
    Bought this car, 2017 Prius Two, used a year ago and the AC never worked. Recently discovered that the hard line to the condenser had been disconnected. Reconnected it and was able to hold a vacuum for 24 hours. Also discovered that the wiring had been disconnected from the AC pressure sensor
    Was getting B1423 before and after re-connection of sensor. A mechanic told me that the code shouldn't come back once the sensor was re-connected. But the code reads "open in pressure sensor circuit/abnormal refrigerant pressure" so wouldn't this just be indicating there was no pressure in the system which there isn't, right?
    I've been trying to find a replacement and most of what I find doesn't match what I have, 1st image Denso 499000-8880. The Toyota part # is 88719-47010 when I search that most of what I find (Oreillys, Napa) resembles the 2nd image with a much wider wiring connector. Anyone experience this?
  2. ChapmanF
    18,458
    Right.
    Carsten likes this.
  3. Carsten
    60
    Columbia, SC
    Thanks
    Any way to test the sensor?
    Just to be sure
  4. ChapmanF
    18,458
    Connect a scan tool that can show live data, and view the pressure sensor reading.
    Attach a manifold gauge to the high-side port and compare the reading on the gauge to the reading from the sensor.
  5. Carsten
    60
    Columbia, SC
    Awesome, thank you!!!
  6. Carsten
    60
    Columbia, SC
    Ok, so I did as you said, i have the Autel Maxi AP200 scanner. The only thing that looked right was "regulator pressure sensor" which gave a live reading of -.67Kpa which is almost no psi. The manifold gauge basically read zero, the needle showed no sign of movement when I opened the valve, it's an Autozone rental.
    Seems like assuming the regular pressure sensor is the right sensor (hadn't heard it called that yet), the fact that it's giving me a reading, and of the expected value, would indicate it is functioning.
  7. ChapmanF
    18,458
    That's how it seems to me too.
  8. Carsten
    60
    Columbia, SC
    Thanks! I really appreciate your help on this
  9. Carsten
    60
    Columbia, SC
    Hey, so I thought I'd go a little further with testing, I put the system under vacuum and the live reading didn't change at all. The reading on my app was odd though, it seemed that the range of measurement was nil. Makes me wonder is it the app or can it not read that far negative?
  10. Leadfoot J. McCoalroller
    8,133
    7,632
    Pennsylvania
    2018 Prius c
    I suspect you are looking at the low-limit reading. There is no operational need for a sensor that can return a pressure reading that low, so they wouldn't have spent the money to include one.
  11. Carsten
    60
    Columbia, SC
    Thanks, kinda figured
  12. Carsten
    60
    Columbia, SC
    Put some compressed air into the system a few days ago and got a reading, 100% confident now. Cool to see the live data in action
    It's since been flushed and recharged, enjoying me some AC
    bisco and Brian1954 like this.
