Does My 12 volt battery appear bad?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Darklandscape, Jul 14, 2024.
  1. Darklandscape
    Darklandscape Junior Member
    64
    I put the car in ready mode and turned just the headlights on. For 20 minutes the 12 volt showed between 13.59-13.85 volts, is it supposed to charge for this long?
    I turned the car off with the headlights on, the car went from 12.56 to 12.21 in 3 minutes.
    Is this a normal level of discharge?
    Battery is 4 years old
  2. Doug McC
    Doug McC Senior Member
    1,080
    420
    Midwest
    2022 Prius
    Your battery is fine. Your method of testing it may not be the best, but it’s fine. As long as there’s a load on it in READY the system will charge at a rate that’s required to compensate for the load.
    Brian1954 likes this.
  3. Mendel Leisk
    41,808
    Look into the new generation of electronic load testers. You use them with car off. If I was shopping for one it’d likely be Solar BA9 (I’m familiar with it predecessor, BA5, which I currently have and use), but there are lots of choices.
    Doug McC likes this.
  4. BiomedO1
    3,995
    2,102
    SacTown, Ca
    That's fine, though an informal test. It would be worrisome if the voltage dropped below 11.75 under the same conditions. I believe you'll start encountering sensor error messages down around 10.5 or less.
    Hope this helps...
  5. bisco
    52,262
    get a free load test at many auto parts stores
  6. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    or buy your own TOPDON BT100 battery tester
    ColoradoBoo and Doug McC like this.
  7. vvillovv
    vvillovv Senior Member
    4,324
    1,511
    NY
    Geb 3 s have a diagnostic mode you get to on the MFD. Look in your owners manual under the MFD stuff.
    It shows amongst other stuff the 12 volt static reading.
    I've never tried this, but it might be possible to see in all three of Prius On states. Acc, On and Ready.
  8. ColoradoBoo
    ColoradoBoo Senior Member
    1,263
    866
    Monument, Colorado USA
    THIS! I love my battery tester and use it all the time.
    FuelMiser likes this.
  9. BiomedO1
    3,995
    2,102
    SacTown, Ca
    Call me old school but I still like the standard carbon pile load testers. It doubles as a hand warmer in the winter.:p:D:ROFLMAO:
    ColoradoBoo and Mendel Leisk like this.
  10. Darklandscape
    64
    I just got Topdon b200,
    How long after turning off the car should I run the load test? Should I let it sit overnight? Should I run any other test.
    My 2020 oem 12 volt should be tested as a flooded, right?
  11. Mendel Leisk
    41,808
    As far as I know these electronic load testers aren’t mislead by “surface charge”, can be used any time. They’ll obviously show higher voltage with a car fresh off a drive (or charger), but they still will get accurate read of the CCA.
    At least that’s the case with my Solar BA5.
    Still, it doesn’t hurt to let the car sit overnight, let voltage settle back.
  12. Doug McC
    1,080
    420
    Midwest
    2022 Prius
    Yes, it should be tested as a flooded. Once you shut the car off turn your headlights on for approximately 30 seconds to remove the surface charge, shut them off and begin your testing. You can check out The Car Care Nut on YouTube as he tests the battery tester you have.
    Additionally you can check out Professor John Kelly from Weber University on YouTube for more information. If I remember correctly, both of them advise to remove the surface charge and in every class I ever had on battery testing I learned you needed to do it (unless you care about accurate results).
    #14
    #14 Doug McC, Jul 21, 2024
  13. Doug McC
    1,080
    420
    Midwest
    2022 Prius
    No, because the charging algorithms programmed into the car are based on a flooded lead acid battery being installed. Again, One of John Kelly’s videos goes into good detail about this. You will however see contrary opinions on this site, and if you follow such advice you could perhaps never notice an issue. Having said that, you could also end up having problems. To me, it just makes more sense to install the correct battery to begin with.
