Alternative Spare Tire
Discussion in 'Gen 5 Prius Accessories and Modifications' started by NullDev, Feb 15, 2024.
  1. purplePriii
    purplePriii Active Member
    275
    122
    Out of curiosity, and if you can, I'd weight that R4P spare and see how much it weighs. It doesn't sound like it'll be much lighter, if at all. I couldn't find a weight for it online.
  2. Templeton
    Templeton Member
    260
    73
    usa
    2024 Prius Prime
    SE
    Not sure if weighing that particular spare would be very useful, as that rim has a completely different tire on it (more suited to a rav4P) than I would need or use for a priusP. And the bigger tire adds a considerable amount of weight.
  3. purplePriii
    275
    122
    I can find tire weight online, can't seem to find OEM spare tire weight online for some reason. I was mostly curious.
  4. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    The OEM steel spare rim and tire are 29 lbs.
    EDIT: Never mind. I thought you were looking for the Prius spare weight.
