P0A0D to no end…
Discussion in 'Gen 3 Prius Technical Discussion' started by Awells80, Jul 15, 2024 at 7:23 PM.
  1. Awells80
    Awells80 New Member
    Louisville, Ky.
    IMG_4173.png IMG_4173.png IMG_4179.png IMG_4069.jpeg IMG_4076.jpeg IMG_3994.jpeg IMG_3985.jpeg Hello to all. I had a hybrid battery that I had to replace a few modules in, so I took it out of the vehicle and did several different load tests on each individual module in different conditions and the failed modules have now been replaced and grid charged to 137v total pack voltage, then discharged, then charged back up, left for 24 hours, checked voltages, then load tested, etc. Everything was fine so I topped off the charge and put the battery pack back in. With the downtime on waiting for charging and discharging, I also cleaned the whole EGR system, which doesn’t amount to much on my concern I don’t think.
    I put the battery is back in and all plugs are plugged in, including the interlocking switch (yes it’s in correctly, 100%). I have tested this circuit and it’s good but the battery voltage sensor ecu is saying otherwise.
    This has been a nightmare and I’m reaching out in hopes of someone out there who has experienced this because I’m out of what the heck to do next.
    Will not go into “READY” mode. Hybrid battery COOLING FAN is on as soon as the ignition is “on” and remains on until I power off the ignition.
    I have replaced all the bus bars and nuts. I have replaced the bus bar wiring harness to the battery ecu and I have also replaced the whole junction relay box with new relays.
    Techstream says as follows:
    P0A0D
    P0AE7
    U029A
    P0453
    Also,
    Anyone know what “connector cover assembly” is in the “ILK” circuit right before it gets to the “air conditioning harness”?
    Thanks in advance. I’ve learned so much from this forum!
  2. ChapmanF
    15,560
    The ECU that's responsible for monitoring the interlock circuit is the power management control ECU.
    Not positive, but in the diagram you are referring to, all three of ("inverter terminal cover", "no. 4 floor wire", and "connector cover assembly") are shown as being within the inverter with converter assembly. My first guess would be that you find more than one independently openable terminal cover on the inverter, and a pair of interlock contacts beneath each one.
    None of those would normally be the cause of a P0A0D unless you had removed any of those covers on the inverter.
    Only the P0A0D code is about the interlock circuit. The other codes you have indicate other issues and should be looked up on their own.
