Rattling my cage
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Suntzu0142, Jul 16, 2024.
  1. Suntzu0142
    Suntzu0142 New Member
    Columbus, ohio
    2015 Prius v wagon
    Ok so here goes first time post as I recently just got forced into buy a prius for my wife.
    The prius in question is a 2015 prius v with ~160k miles
    We purchased the vehicle a couple months back after our son totalled out 2012 tsx , my wife found this car at a local smaller car lot and fell in love with it.
    There was a CEL on whe. We purchased it it was for an 02 sensor which I quickly replaced and all was well for a few weeks. Then the CEL came on again for a misfire on cylinders 3,4 .... so the weekend came around and I decided to pull the plugs for and inspection all seemed in fairly poor condition and since it was a small pain to get to them I decided to replace the coils as well hopefully to not just have to do it in another week or if it didn't resolved the codes...
    The car drove fine for around another week no CEL then again with misfire on 1 and 4 so that weekend I rechecked all the plugs and decided to check the intake since it's a know issue on them and replace the pvc valve while I was there pull intake cleaned as best as I could since it was pretty bad used 3 cans of parts cleaner, and decided to replace the injectors since the ones in it looked to be original from factory. The shake on start up was gone and no lights for a fee more days and again misfire codes... I can't remember the cylinders this time... so after more research here on the forum decided come the weekend to check the egr pipe,valve,cooler.
    There was alot of carbon build upto soaked everything minus the electronic connectors etc in berrymans cleaners and it did a wonderful job cleaning everything rinsed with ro/di water then allowed toa ir dry for 2 days and painfully reassembled everything.
    Now it has developed a "sputter" as I'm gonna call it when you barely touch the accelerator, and after 20-30 mins running throws misc cylinder misfire codes all different... I have un hooked the egr system plug cleared codes and the only code it throws of coarse is for the egr system... but no misfires no sputtering runs amazing...
    I ordered a new egr valve, my thinking is maybe there's something wrong with the magnetic part of the egr valve causing issues but I'm at my whits end trying to figure this thing out any help or shops people can recommend columbus ohio would be greatly appreciated.
  2. Suntzu0142
    Columbus, ohio
    2015 Prius v wagon
    These are pics before and after cleaning egr valve
  3. rjparker
    10,117
    6,279
    General! We have fired the parts cannon and are out of ammunition! But the enemy is still advancing and seems to be in full force!
    Simply block the egr flow to eliminate egr. Egr rarely causes misfires anyway and causes rough idle only if stuck open.
    95% head gasket. Even without obvious coolant loss, with negative combustion gas in coolant and or with negative leak down test.
    Dual view borescope is the weapon of choice.
    douglasjre likes this.
  4. Mendel Leisk
    41,384
    If and when you do the head gasket, do a full EGR clean as well. See first two links in my signature (on a phone turn it landscape to see signatures).
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    were the 2015 models prone to HG failures? I thought that was solved by 2015 model year?
  6. bisco
    51,882
    the theory goes that they got new piston and ring design, so less egr build up. but it still needs to be cleaned.
    or if you believe toyota, it's a coolant pump software issue.
    or if you believe some posters here, it's the 10k oil changes.
    or if you believe the car care NUT, it's the acidic coolant and toyotas lack of coolant change recommendation frequency
  7. rjparker
    10,117
    6,279
    Gasketmasters latest videos recommend preemptive hg changes on all gen3s and rebuilt once they blow (“in stock”).
    Rebuilt gets you another 150k miles with a better hg (even from Toyota), better pistons, rings and probably the better intake and egr valve. There is no doubt the gen3 low tension rings cause oil burning or excessive oil burning which multiplies carbon buildup and preignition.
    Many 2007-15 Toyota models including Camry, Corolla, RAV4, Solera, Matrix and Scion also were oil burners with low tension rings but only Prius and a low volume Camry hybrid had a thermal cycling Atkinson cycle engine.
    #7 rjparker, Jul 16, 2024
  8. Mendel Leisk
    41,384
    Just editorial:
    Gen 4 fixed the EGR system "shortcomings", but had the misfortune of Exhaust Heat Recover system failures, leaking coolant, this time just into the exhaust, but with protracted neglect could also lead to head gasket failure. More than a few were also misdiagnosed, mechanics seeing (EHR) coolant loss and changing head gasket.
    Gen 4 press release, with "revised" EGR system mention, attached:
    #8 Mendel Leisk, Jul 17, 2024
  9. ChapmanF
    18,123
    The press release does mention "new EGR system with cooler" as a bullet point. The gen 4 adopted a "catalyzed EGR" system, reflecting industrywide research that was being conducted and published during the gen 3 development years.
  10. Mendel Leisk
    41,384
    Translation: they connected the EGR system past the catalytic converter, instead of before it. Presumably with the aim of having less carbon in the system. They also more or less doubled the cross-sectional area of the cooler.
    Just running a few of the prototype gen 3's, say for 200K miles, and they would have seen the excess carbon build-up in EGR system. And the runaway oil consumption due to "low tension" rings. And likely blown head gaskets.
  11. ChapmanF
    18,123
    The "translation" may not be necessary; the published engineering literature, which came from the research being conducted industrywide, kind of covers it.
    Moving to catalyzed EGR changes the chemical constituents of the exhaust gas and changes its effects on combustion; that was a significant area of the research.
    The increased cross-sectional area of the cooler and the rest of the plumbing follows directly from the lower pressure of the exhaust gas past the cat, and what cross-sectional area is needed to obtain the intended flow at that lower pressure.
    I have not said anything here that Mendel hasn't seen before.
  12. Mendel Leisk
    41,384
    Still, 3rd gen EGR system will be near-completely clogged by 200K miles. 4th gen system with over 300K, just a light dusting*. That's engineering advance for sure.
    * reported by @jerrymildred, from work experience at Tampa Hybrid.
    V Sport Wagon likes this.
  13. rjparker
    10,117
    6,279
    There is no doubt “egr cooler cleaning” is unheard of before or after gen3.
    Toyota management pushed their gen3 engineers to gain mpg while reducing costs. Result 1: the gen3 cat has less precious medals through the addition of a suspect egr system to maintain low US/carb state emissions. Result 2: New inverters failed without warning. Result 3: Cylinder cooling distribution was compromised. Result 4: Low tension rings to increase gen3 mpg while multiple other low tension Toyota engines beginning in 2007 had excessive oil consumption - including their flagship Camry which updated their rings in 2012.
    Apparently some countries had no egr on gen3.
    Interestingly the gen3 system was sold in other countries through 2021 in the v/alpha/+ without widespread reliability failures.
    #13 rjparker, Jul 17, 2024
  14. Suntzu0142
    Columbus, ohio
    2015 Prius v wagon
    Ok so here's an update took to a mechanic at a local higher end toyota dealership paid him to look at it in his "downtime" and "off the clock" he ran a leak test and no headgasket leaks being shown, did a smoke test and no leaks found has now developed a p0420 CEL( along with random misfire codes, and he cant find any reason for it he said the A/F airflow ratio continues to move all over the place and just won't "harmonize" the way it should, he said he has relearned the idle 3 times and updated all the software. He said the p0420 code could be either a bad cat OR a bad 02 sensor... and could be causing the misfires but is doing more checks today, gonna endoscope the cyclinders and continue searching ... said it may be an ecu programming issue ... still searching for answers before I do anything else ..
  15. rjparker
    10,117
    6,279
    If the new egr valve was installed or the egr flow was manually blocked the egr is not causing misfires.
    A head gasket intermittent leak of coolant into the cylinder is a well known problem with these engines.
    Have your mechanic do a cold engine dual view borescope cylinder inspection with a manually pressurized coolant system. What he is likely to see is a steamed cleaned piston, possibly a drop or two of coolant dripping from the head gasket and maybe a scored cylinder wall. Any of those means a head gasket or a rebuilt engine is needed.
    Car Care Nut HG Borescope at 7:40
    P0420 is almost always a bad cat based on an automatic test that can judge the cats efficiency. The sensors have their own tests.
  16. douglasjre
    douglasjre Senior Member
    2,177
    717
    Null, NL
    The seller knew all this. What craigslist flipper sold it to u
  17. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    Yes, seen many 15's with head gasket issues. "But they had the reflash, updated intake and EGR and didn't burn oil".....so? 2016-17' Gen 3 Prius V and CT200h models don't seem to have the problem. Riddle me that, Riddler.
  18. V Sport Wagon
    375
    131
    Southern California
    No, the P0420 will give a description on Tech Stream what sensor or bank it is, signifying upper/lower etc. The only time the Cat will be the problem is if you replace both sensors and it still comes back and throws that DTC. Maybe it's the APP or cheap auto zone scanner you all are using? Sensors are way cheaper anyway, why would you make someone buy a $2000 exhaust pipe w/cat before you diagnosed what tech stream says?
  19. ChapmanF
    18,123
    While the code, as rjparker said, is set by an automatic test that is meant to be specific to cat converter performance, and the sensors do have their own tests (which prevent this test from even running if they fail), it's also true that the cat test can be influenced by a whole range of things including sensor issues (not severe enough to set their own codes), leaky exhaust, even the EGR system, so there are troubleshooting steps worth working through before condemning the cat.
    If I remember right, @mr_guy_mann has posted knowledgeably about working up P0420 in puzzling cases.
  20. V Sport Wagon
    375
    131
    Southern California
    Tech Stream literally gives the description and/or sub codes to tell the tech where to look and what the actual problem is. Always take your car to a certified mechanic instead of wasting time and money.
