Okay. Who HASN'T had a 12V battery issue with their 2023-24 Prime?
Discussion in 'Gen 5 Prius Main Forum' started by REBobBecker, Mar 30, 2024.
  1. GcinFl
    GcinFl New Member
    2024 Prius
    What about those of us with non-Prime HEV models? My 12V drains quickly. After driving, it never charges to above 12.35. Then in 2 days of sitting it will be down to 12.06 or so. First scheduled maintenance will be in July. Hopefully they'll have a solution.
  2. Maturedriver
    Maturedriver Junior Member
    56
    46
    England
    2024 Prius Prime
    Has your dealer installed a tracker?
    GcinFl likes this.
  3. Paul Gregory
    Paul Gregory Active Member
    438
    119
    Alberta
    2024 Prius Prime
    XSE
    I had some serious issues, but nothing since I installed a battery maintainer. I was unable to start the car once, while leaving it parked overnight at a hotel. Since then I've carried an extension cord and made sure to plug in the maintainer overnight.
    I also have an auxiliary battery, like on a camper. It fits nicely into the space near the left rear fender. It's connected to the main 12V battery through a VSR isolator, which prevents the auxiliary battery draining when parked. The Voltage Sensitive Relay (VSR) cuts in at 13.3 volts and cuts out at 12.8 volts to ensure the primary battery is always charged and ready to start the vehicle.
    If the auxiliary battery goes dead from running the drink cooler overnight, it only takes less than an hour to charge it up again through the isolator connection. I have also rigged a heavy duty bypass switch around the isolator, with a 30 amp fuse, in case I need to "boost" the primary battery. So far, the bypass current has never exceeded 10 amps.
    #123 Paul Gregory, Jun 23, 2024
  4. bisco
    49,434
    having to keep a maintainer on it is a real plug for toyota engineering
    GcinFl likes this.
  5. Jay Edelman
    Jay Edelman New Member
    Monterey
    2023 Prius Prime
    XSE
    I went on travel for exactly two weeks and when I returned from our flight the battery was too low to start the car. Unfortunately it never gave me a clear indication of why it wouldn't start, so I kept trying until the battery was well and truly dead. I find it very unreasonable that an otherwise regularly driven and maintained new car can't sit in a long-term parking lot for two weeks in moderate temperatures and humidity without draining completely. In my mind, that's a serious design or engineering flaw.
  6. Rafsdhc6
    Rafsdhc6 Junior Member
    Ontario
    2023 Prius Prime
    XSE
    Which point for the -negative connection did you end up using?
    Alessandro_Ibi likes this.
  7. Yvrdriver
    Yvrdriver Member
    37
    Vancouver
    There's a youtube channel based in Japan that did some reporting on the rear door issue. As it happens, the channel also posted a recent video on what I assume is the 12v battery issue. I'm relying on the auto-translate, so if there's a Japanese speaker on the forum, maybe they can have a listen?
    The translation refers to the battery as the auxiliary battery, which I assume is the 12v. The channel believes a recall will happen for this issue at some point.
    Apparently the 2 middle cells of the battery are getting damaged. They could be getting damaged simply via the installation of the battery in the car...something about a protrusion in the Prius that is impacting the battery? Or maybe the cells are just defective. Anyhow, it's interesting to see someone based in Japan also reporting on this issue.
    Julio_E likes this.
  8. Gokhan
    Gokhan Senior Member
    4,638
    1,861
    Paramount CA
    @Salamander_King is fluent in Japanese.
    Yvrdriver likes this.
