Okay. Who HASN'T had a 12V battery issue with their 2023-24 Prime?
Discussion in 'Gen 5 Prius Main Forum' started by REBobBecker, Mar 30, 2024.
  1. GcinFl
    GcinFl New Member
    2024 Prius
    What about those of us with non-Prime HEV models? My 12V drains quickly. After driving, it never charges to above 12.35. Then in 2 days of sitting it will be down to 12.06 or so. First scheduled maintenance will be in July. Hopefully they'll have a solution.
  2. Maturedriver
    Maturedriver Junior Member
    56
    46
    England
    2024 Prius Prime
    Has your dealer installed a tracker?
    GcinFl likes this.
  3. Paul Gregory
    Paul Gregory Active Member
    438
    119
    Alberta
    2024 Prius Prime
    XSE
    I had some serious issues, but nothing since I installed a battery maintainer. I was unable to start the car once, while leaving it parked overnight at a hotel. Since then I've carried an extension cord and made sure to plug in the maintainer overnight.
    I also have an auxiliary battery, like on a camper. It fits nicely into the space near the left rear fender. It's connected to the main 12V battery through a VSR isolator, which prevents the auxiliary battery draining when parked. The Voltage Sensitive Relay (VSR) cuts in at 13.3 volts and cuts out at 12.8 volts to ensure the primary battery is always charged and ready to start the vehicle.
    If the auxiliary battery goes dead from running the drink cooler overnight, it only takes less than an hour to charge it up again through the isolator connection. I have also rigged a heavy duty bypass switch around the isolator, with a 30 amp fuse, in case I need to "boost" the primary battery. So far, the bypass current has never exceeded 10 amps.
    #123 Paul Gregory, Jun 23, 2024
  4. bisco
    49,441
    having to keep a maintainer on it is a real plug for toyota engineering
    GcinFl likes this.
  5. Jay Edelman
    Jay Edelman New Member
    Monterey
    2023 Prius Prime
    XSE
    I went on travel for exactly two weeks and when I returned from our flight the battery was too low to start the car. Unfortunately it never gave me a clear indication of why it wouldn't start, so I kept trying until the battery was well and truly dead. I find it very unreasonable that an otherwise regularly driven and maintained new car can't sit in a long-term parking lot for two weeks in moderate temperatures and humidity without draining completely. In my mind, that's a serious design or engineering flaw.
  6. Rafsdhc6
    Rafsdhc6 Junior Member
    Ontario
    2023 Prius Prime
    XSE
    Which point for the -negative connection did you end up using?
    Alessandro_Ibi likes this.
  7. Yvrdriver
    Yvrdriver Member
    39
    Vancouver
    There's a youtube channel based in Japan that did some reporting on the rear door issue. As it happens, the channel also posted a recent video on what I assume is the 12v battery issue. I'm relying on the auto-translate, so if there's a Japanese speaker on the forum, maybe they can have a listen?
    The translation refers to the battery as the auxiliary battery, which I assume is the 12v. The channel believes a recall will happen for this issue at some point.
    Apparently the 2 middle cells of the battery are getting damaged. They could be getting damaged simply via the installation of the battery in the car...something about a protrusion in the Prius that is impacting the battery? Or maybe the cells are just defective. Anyhow, it's interesting to see someone based in Japan also reporting on this issue.
    bisco, GcinFl and Julio_E like this.
  8. Gokhan
    Gokhan Senior Member
    4,641
    1,863
    Paramount CA
    @Salamander_King is fluent in Japanese.
    Yvrdriver likes this.
  9. Julio_E
    Julio_E New Member
    Michigan
    Hi. Newer member here and eagerly awaiting a 2024 Prius Prime due to arrive early next month. Been following this battery issue here. I watched the whole video with auto-translate on and I think the auto-translate also said the damage referred to led to "leaking of the battery" somehow and actually caused rust in his car along with the car not able to start anymore due to the weak battery. In auto-translating the comments, it seems he said he knows of two cases of "fluid leaks".
    It will be helpful if someone can better translate all of it.
  10. Salamander_King
    Salamander_King Senior Member
    10,974
    8,860
    New England
    Checked the video. The summary by @Yvrdriver is right on. But there really isn't anything technical that he is discussing. I did not dig deeper, but sounds like he works at a Toyota dealership, But his opinion on "recall" on the failing 12v battery seems to be based on just 2 incidence he knows at his shop. In both cases, the 12v battery was cracked and leaked. He is speculating that may be due to manufacturing defect of the battery or the installation problem, but without any evidence to support it.
    So, all in all, I take it as just another YouTuber blowing air without much substance. I have noticed the "12v battery" problem in almost any modern car forum. My current drive Escape PHEV has a thread on it that is now 14 pages long. People report problem and some had replaced the 12v battery under warranty two, three times. In most cases replacing the small OEM lead-acid battery to a bigger AGM battery solved the problem for many. But the fact it does not happen to every one, means there are some user case variable that affects the longevity of the 12v battery. Mine is now 18 month old, and so far no problem. I think in many cases, it is an operator error, such as keeping the car in "ACC" mode too long with high wattage items such as AC on that causes the initial drain on the 12v battery, when this situation is aggravated with low frequency short drives, the small OEM 12v battery just do not last long. This is not uniquely Gen5 Prius problem. That's just my 2 cents.
    #130 Salamander_King, Jul 17, 2024 at 8:08 AM
  11. Trollbait
    11,540
    The HHR had its 12V replaced under warranty while still in my father's possession; bad cell. Defects happen, and even low incidences will seem like a lot when millions are made.
  12. bisco
    49,441
    doesn't sound like the problem most owners are having. the affected cars are draining the battery too quickly when off and unplugged, from what i have read
    Julio_E likes this.
  13. Mr.Vanvandenburg
    1,044
    354
    2020 Prius Prime
    From Chrysler owners manual about 1998.
    I don’t know how Gokhan managed six weeks, but he did.
    VEHICLE STORAGE
    If you are leaving your vehicle dormant for more than 21
    days you may want to take steps to protect your battery.
    You may do the following:
    • Remove the 20 Amp mini-fuse in the Integrated Power
    Module labeled Ignition-Off Draw (IOD).
    • Or, disconnect the negative cable from the battery
