2008 Prius "Park Button" Not Working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius Newby, Jul 13, 2024 at 9:07 AM.
  1. Prius Newby
    Prius Newby Junior Member
    Montana
    The Park Button won't engage park (and therefore, disengage?), and when I shift into Reverse or Drive, the transmission almost immediately shifts back into Neutral (as indicated on the digital gear indicator).
    About 10,000 miles ago I drained and refilled the transmission twice with Toyota WS trans fluid. No leaks.
    No odd dash lights are illuminated.
    What is the problem?
    49,444
    how is the 12v health?
  3. ChapmanF
    15,569
    A scan tool will probably show some C23xx trouble codes. Those would be helpful.
  4. Prius Newby
    Montana
    Replaced the 12V battery in March, though haven't measured voltage since this Parking Button problem started yesterday.
  5. Prius Newby
    Montana
    I have simple OBD2 reader, will this read the "C" codes you mentioned?
  6. ChapmanF
    15,569
    Simple way to find out....
  7. Prius Newby
    Montana
    True, it's pushing 100 degrees here so I'll check in the am and report back here.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    3,461
    1,505
    NJ-USA
    Brian1954 likes this.
  9. Prius Newby
    Montana
    Update:
    My OBD2 reader didn't indicate any codes.
    Today the parking button is functioning 100% correctly, and the transmission is shifting into gear and staying in gear as it should.
    WTH?
  10. bisco
    49,444
    get a free load test on the 12v at many auto parts stores
  11. Prius Newby
    Montana
    I followed a YouTube video and checked the 12V battery...Checked out great.
    I am baffled, and open to more ideas on the cause and how to permanently resolve this "phantom issue".
    My wife is about to drive the Prius 100 miles tonight, so she will give me a report.
  12. mr_guy_mann
    3,461
    1,505
    NJ-USA
    If there was something causing a problem, most of the ecu's will retain "history" codes (for awhile, so long as the 12V battery hasn't been disconnected), even if there are no active problems or warning lights on.
    You would need a capable scantool to check this. Or you can wait until it causes more problems - possibly somewhere inconvenient.
