Steering rack makes rattling noises over bumps
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by douglasjre, Jul 18, 2024.
  1. douglasjre
    douglasjre Senior Member
    2,179
    718
    Null, NL
    It's not the ball joints because I already replaced those. I even replaced the lower control arms. Got new shocks and struts. There's some rattling inside the rack. When I go over potholes. It started after spending a year in New York City with the car. Is there a way of tightening this like a lash adjustment or is it needing a new rack?
  2. Tombukt2
    12,957
    2,325
    There used to be a big hex adjusting nut that adjusted the sea washer or c looking piece of metal against the rack and it's lubrication inside I think that's been taken away now It's no longer on the Toyota racks The place where it goes is there you can see it's a big oh I don't know 27 mm or something whole or it would be a hole The land is there where the hole would be drilled but there's nothing drilled and then on later models the casting has been changed doesn't even show where that point would be so I think the adjustment is gone.
  3. JC91006
    JC91006 Senior Member
    16,768
    8,565
    I have this exact issue, on 2 of my gen2 prius. 2005 and 2008. I have not figured out what the cause is, the steering is nice and tight so it's not a problem with the intermediate shaft. I hope someone can get to the bottom of this
    douglasjre likes this.
  4. Eddie25
    Eddie25 Active Member
    497
    209
    MI
    douglasjre and bisco like this.
  5. JC91006
    16,768
    8,565
    I looked this part up for the 2nd gen cars, it's showing not compatible. Maybe just for the 3rd gen.....
