Needing to find a switched 12V fuse under the hood
Discussion in 'Gen 2 Prius Main Forum' started by ColoradoCrow, Jul 17, 2024.
  1. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    462
    Leawood, KS
    I
    Hi all. I installed fog lights and need to tap into the 12V power supply under the hood at the fuse box. All the fuses I have metered are 12Volt all the time which makes sense. The trouble is I’m running an illuminated rocker switch for the fog lights which will drain the battery. I have found a switched wire inside the car but I need to find one under the hood. any ideas?
  2. ColoradoCrow
    1,108
    462
    Leawood, KS
    I
    Good morning. It would make sense that the fuses have constant 12volt on both sides of the switch as I’m looking for a source after the ignition switch. I even tried the fog light 7.5 fuse which is labeled on the fuse box to no avail. I’m trying to avoid having to run another wire through the firewall but Inthink I am going to have to do this. Any thoughts?
  3. BiomedO1
    3,468
    1,804
    SacTown, Ca
    Put a relay under the hood. Fused and constant hot on one side of relay. The existing wire going through the firewall becomes a switching wire to turn the relay on-off. Power tap into an accessory switched wire under the dash to your illuminated switch, that way when ignition is off you lose power to the switch and the fogs goes off automatically. You won't be able to power the fogs without turning-on the car.
    Good Luck....
    ColoradoCrow likes this.
  4. ColoradoCrow
    1,108
    462
    Leawood, KS
    I
    Thanks. It is a Nilight wiring harness for 16awg 2 fog light kit. There is a relay. But I agree with having it connect to switches power. I will have to run a second wire from the power to a switched power wire behind the radio. It seems. I’ll take the dash apart again to locate one
  5. rjparker
    10,073
    6,239
    The IG2 ignition relay is in the engine fuse box as part of a module called Unit B. You could tap its output under the fuse box to drive a relay. The same relay feeds 12v to the coils and other devices on the engine.
  6. ColoradoCrow
    1,108
    462
    Leawood, KS
    I
    TY RJ THIS WORKED OUT GREAT. I added a tap to one of the empty slots under Unit B and now have switched power for the fog lights.
    I will upload photos shortly. I have pics of the rocker switch and the Lights themselves. This will help out night driving in the winter for sure.
