Okay. Who HASN'T had a 12V battery issue with their 2023-24 Prime?
Discussion in 'Gen 5 Prius Main Forum' started by REBobBecker, Mar 30, 2024.
  1. bisco
    49,473
    Agreed. My bolt recommends leaving it plugged in when not in use.
    It keeps both batteries conditioned that way
    Trollbait likes this.
  2. Mr.Vanvandenburg
    1,053
    361
    2020 Prius Prime
    bisco and Trollbait like this.
  3. Trollbait
    11,557
    What makes a long trip, and how frequent, for keeping the 12V charged?
    The annual car mileage in Japan is under 7000km, or well under 5000 miles. If this was mostly an issue of the owners not taking proper care of the 12V, it would seem there would be a lot of dead ones there.
    There seems to be a case where the software isn't putting a system into sleep mode under certain conditions. Though I think that bad batch of batteries played a part. Whether they were bad from a defect or improper storage doesn't matter.
    Owner's manuals provide two things; important information for the operator, and a CYA for the manufacturer. I believe the warning Toyota gave about the 12V battery and charging is the latter.
    The 12V is charged while the traction pack is being charged, the battery heater is own, and whenever else the car calls for power from the outlet. The addition drain happens when power isn't called for, as the system monitoring for the conditions to call for power. Keeping the charge cord depowered when not needed is a safety feature.
    Other EV makers have 'maintain the 12V' as a reason for the car to draw power from the outlet. Some even will do so from their traction pack when not plugged in. Toyota likely also do so, but the drain over a couple days likely isn't enough to be a concern. That is until other issues with the 12V are present.
    You got a like for keeping it polite.
