What I did was...found out that my aftermarket center caps don't fit
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Shammo, Jul 14, 2024.
  1. Shammo
    Shammo New Member
    SE Pa
    2022 Prius
    L Eco
    Mistakenly thought that all the Prius wheels have the same center ID. I see now that they don't.
    So I don't end up with more that won't fit, what dimensions are needed to get the right size centers?
    Just got this car and all 4 centers are gone, i hate to see the rims w/o them. I don't have a caliper big enough to measure the ID of the wheel center. Looks to be 2" +/-
    2022 ECO
    Thanks
    Shammo
  2. Mendel Leisk
    41,863
    3rd and 4th Gen I believe have the same bore diameter, but there’s a groove inside the bore (for the locking clips), and it’s location varies between the two gens.
    when I bought some cheap, Gen 3 E-Bay caps, purported to be genuine Toyota (they definitely weren’t), they wouldn’t sit properly. Comparing them to genuine (our 2010 CDN Touring came with 17” rims, with the centre caps), I saw the E-Bay caps had slight protrusions on the backside of the outer flange. With a little Dremel work I was able to get them to fit.
    It’s not just the bore diameter; there’s lots of factors. I would start by researching the genuine Toyota part numbers, search for that. Listing for knock-off caps may mention being compatible with that part number. Also check the price for genuine at dealership parts departments, and/or online dealerships too, though they’ll likely be pricey.
    Toyota USA parts website is a mess now (by design?); the dead-simple way to find out the correct part no would be to phone a parts dealership. And they’ll be able to sell you the correct, properly fitting cap, albeit more costly.
    #2 Mendel Leisk, Jul 15, 2024
    Doug McC likes this.
  3. Robert21PrimeLTD
    88
    42
    Nashville
    I purchased Toyota part # 42603-52170 from Amazon and they fit my 2021 perfectly.
  4. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
    Aftermarket ones I got fit fine
  5. SmokeyPete
    SmokeyPete New Member
    Central MA, USA
    I have a 2017 Prius Prime. I just bought it used. I went to the local Pull-Apart and spent 30 minutes picking through a bucket to find what I wanted. They charged me $2 to get in and could have cared less on what caps I took home. I found that for the original equipment without the wheel covers, the Nissan caps were a good fit, overly abundant and best of all Free.
    Shout out to my local Pull-A-Part, (Sam's) Linder's in Worcester MA
