Radio Wires not Transmitting enough power
Discussion in 'Gen 2 Prius Audio and Electronics' started by brvnden, Jul 21, 2024 at 1:02 PM.
  1. brvnden
    brvnden New Member
    Today
    Antelope Valley
    I’m swapping the radio system in my 2005 prius, and after taking out the stock radio the wires are only transmitting about .5 volts instead of 12. All fuses have been checked and the new radio works. Any tips?
  2. Tombukt2
    9,131
    1,585
    There's only one or two power wires right The rest are speaker and what have you so you are measuring the correct wire/s?.. And believe me Mysterio needs the 12 volts that it gets from the necessary wires.
  3. bisco
    49,484
  4. ChapmanF
    15,610
    Double-check the diagrams and what's being measured?
