P0301 HG vs EGR vs valves?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ScottFree, Jul 22, 2024.
  1. ScottFree
    ScottFree New Member
    Idaho
    I bought my 2010 new. It now has 265K, with the last 4 years only being about 15K. The last real service done by the dealer was 150K.
    I've tried to help myself here by reading many HG related threads. My case doesn't seem clear to me.
    It has had the cold start rough wobble occasionally since around 60K miles from what I can remember. The perfect conditions: cold outside temperature, under freezing helps I think. Move the car in the drive way from one spot to another allowing the ICE to run only for 5 seconds. Leave it over night. The next time you start, guaranteed wobbling. It never threw an error code.
    I never knew to do an EGR clean out until the last few weeks as I've followed many threads now. It may have never been done. It may have been done by the dealer at 150K.
    I did the paper test for for coolant spit out of the spark plug holes. I see in another thread a month or 2 ago, that this test is looked down on. I did the exhaust gas leak test on the coolant by pulling the coolant gas through the blue solution and see if it turns yellow. Also, looked down on here. Both seemed good, no splattering on paper, and it didn't turn yellow. (although after about 5 minutes it turned a blue-green)
    That said, maybe below is better information.
    Spark plugs:
    #1 looked dirty, #4 looked almost as dirty,
    #2 and #3 were not as dirty and more dry looking.
    None looked "steam cleaned."
    I have a cheap scope I bought for another project a year ago. It only has 1 camera pointed down. Looking down into the cylinders:
    #1 looks dark wet but oily wet, kind of small shiny beads
    #2 looks dry, not dark, not shiny, kind of flat gray
    #3 looks dry, not dark, not shiny, kind of flat gray
    #4 looks like #1 but not as "bad"
    (oily grunge, is that valves?)
    I had not added coolant in probably 6 years, I know it was getting lower through out that time. Noticed that it might be dangerously low when checking the P0301 and added to the reservoir. (maybe I got hot bubbles that helped warp the head?)
    Before the P0301, I filled up my tank with gas -- took about 9.3 gallons. I had a rough start about 10 miles after and the P0301. (maybe bad gas? fuel filter? fuel injectors?)
    I've replaced the spark plugs. I've swapped 1&2 coils and 3&4 coils. Some wobble on start still. After 20 miles, checked new spark plugs and they look uglier in 1&4 still.
    I've never had white smoke or black/blue smoke out the exhaust. I've never had signs of coolant in the oil, although I haven't drained it for a change in 4 months.
    Current Plan:
    1. Clean out EGR and replace PCV
    2. Clean fuel injectors and replace fuel filter
    3. If those don't help, HG replacement and machine shop for surface and maybe valves?
    I'd say HG right off, but I don't know what I'm seeing with the scope down #1. I'd welcome thoughts on this.
    Thanks,
    Scott
    #1 ScottFree, Jul 22, 2024
  2. ScottFree
    Idaho
    I just read T-SB-0010-12. That explains the cold start wobble/rough/knock. My dealership claimed they hadn't heard of that before when I explained it ~2013. <sigh>
  3. ScottFree
    Idaho
    I realized that my last comment was confusing. The TSB explains the long term cold start wobble/rough/knock of years past. It doesn't really explain my current problem.
  4. Tombukt2
    12,698
    2,269
    You too just pull your plugs out look at the insulators with the magnifying glass smell them put your finger on it touch your tongue You waft that ethylene glycol? There's your problem You can also whip the other ones out and look down there with an inspection camera if you need to you'll find what's putting your fire out pretty quickly.
  5. ChapmanF
    17,783
    You've just described the perfect conditions for the issue in T-SB-0010-12. You seem to be saying that doesn't seem to fit what's happening now? Can you elaborate?
  6. ASRDogman
    ASRDogman Senior Member
    7,450
    3,872
    You may or may not have a leaking head gasket.
    You said you only let the engine run for 5 seconds then let it sit over night?
    Likely some of the fuel didn't get burnt off and sits on the piston. Next morning, even
    more fuel is pumped into the cylinder, thus the knocking. This is normal.
    Did you do a leak down test? And what coolant gas are you talking about?????
    If coolant "spits" out of the cylinders, the engine is gone. All the other "test" for the head gasket
    really don't work for the Prius.
    Drive the car long enough for the engine to get to operating temp. Let it sit for an hour or so.
    Or even over night. Then start the car. When the engine starts, does it knock? If it does, it's likely
    coolant leaking into the cylinder as the engine cools.
    Anytime the engine starts, let it run until it turns off on it's own.
    You should take the car to a place that's works on Prius. They SHOULD know the car, and know
    how to check for a leaking head gasket.
    You haven't add coolant in 6 years???? Which means you've never changed it. Have you changed the
    engine oil? Or inverter coolant?
    The small shiny beeds are likely coolant. Oil doesn't do that unless in contact with water.
  7. ChapmanF
    17,783
    There was a TSB about those exact conditions. Toyota's conclusion involved water condensed from the exhaust in the small intake manifold passages.
  8. rjparker
    9,897
    6,104
    A dealer won’t work on an egr unless it is coding. They don’t believe the Priuschat egr theory.
    A good engine does not use or lose coolant. Even in 100,000 miles. Of course it would be useful to change the coolant at least every 100,000. There is an equally questionable theory that old coolant can eat away at the head gasket sealing surface.
  9. ScottFree
    Idaho
    Yes. I was able to trigger the wobble/knock easily with those steps every time. Of course, it was rare and after I learned (conclusively) what triggered it avoided letting the ICE run for only 5 seconds. I wish I would have parked it over night at the dealer with those condiitions, and had them go start it. :) We learn.
    The wobble/knock problem now is summer ICE starts with ambient air 70-95 F. When the engine is warm or "cold." It can happen at a stop light for example. How often -- I detect it maybe 50% of the time in the last 50 ICE starts.
  10. ScottFree
    Idaho
    No leak down test yet, no.
    The test kit I used pulls the "air" from the coolant reservoir and bubbles it up through a solution. Similar to "BT-500 Head Gasket Combustion Leak Test Kit" on Amazon.
    Yeah, I haven't added coolant in 6 years, never changed. I do change the oil regularly. I have never changed the inverter coolant since the 150K dealer service. Being honest. Yeah, I agree I didn't treat it very well -- I feel you all shaking your heads, saying "that's what you get."
    I appreciate the education I've got here on PriusChat! I see people are greatly committed for the long term.
    Without creating a bunch of replies, I want to say thank you:
    rjparker, ChapmanF, ASRDogman, and Tombukt2
  11. Tombukt2
    12,698
    2,269
    I don't monitor my coolant very often either 6 years wouldn't be irregular for one of my cars to make on its coolant at least in three of the four on the '09 some coolant disappears out of the radiator nobody knows where it's going I don't see it unplugs there's no stumble there's no funny business but every 10 days if I uncap the radiator the reservoir is full or close to it The radiator if I pour coolant in slowly I can add almost a quart until it stands at the top of the neck at the hole where it rolls over to the reservoir doesn't gurgle down anymore Cap it back up about 10 12 days I'll check it again the reservoir still full but I can add about a quart to the radiator itself If I don't check it and do nothing in about a month I'll be traveling down the highway and my red triangle will come on and go off just randomly intermittently and I know that I'm low enough on coolant that I need to do what I just described and at that point I'll be adding close to two quarts maybe but I can't find it anywhere. And the inverter same doesn't leak or do anything I almost never check it I see it's pink in the jug and leave it alone I'm not running a stock inverter pump so that's never the problem anymore If I was to do anything I might test the pH at 5 or 6 years just to make sure I'm not eating any metal alive.
