2015 Prius c BROKEN FRONT TURN SIGNAL WIRES
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by CARSFAN4, Jul 17, 2024 at 1:36 AM.
  1. CARSFAN4
    CARSFAN4 Junior Member
    24
    Los Angeles
    2015 Prius c
    I need to know what wire colors to reconnect with the front turn signal assembly. There are r colored wires: one green, 2nd green and a white & black strip. Does somebody know how to reconnect them??
    Thanks
  2. ChapmanF
    15,616
    CARSFAN4 likes this.
  3. CARSFAN4
    24
    Los Angeles
    2015 Prius c
    They broke exactly after the bulb socket and I ordered a new one in Amazon.
    The new one has only 2 wires: a blue one and a green one so which one do I connect with the original harness 3 wires.
    These have the following colors: purple, green and black stripes with white.
    Need help please!!!
  4. ChapmanF
    15,616
    That makes it sound as if the c is using dual-filament bulbs for front turn and marker, and your new two-wire socket may not be up to the job.
    Toyota mostly uses white-with-black-stripe for ground, so I'm comfortable making that call, but not which of purple and green is which.
    You could look in your wiring diagram, or grab your meter and see which one comes on with the turn signals and which one with the taillights.
