2012 Prius struggling during first 10 minutes during high heat
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PbRius2012, Jul 18, 2024.
  1. PbRius2012
    PbRius2012 New Member
    New York
    First post, I am not nearly as knowledgeable as you all, so I’m hoping that you can give me some insight based on what I’m describing. Also, I’m not looking for a lot of DIY work, as I don’t have the skills or time to take that on. I’m trying to see if what I’m describing can be fixed by a mechanic and if it’s worth it.
    2012 Prius, original owner, 213k miles. Mostly highway for the first 180 or so, then more city type driving since then. This summer, on really hot days (85 degreees F and higher), the car is really struggling for about the first 10 minutes of driving. The battery meter stays around 2 or 3 bars, and the engine is running the entire time. During acceleration, it seems like it’s getting zero help from the electric motor. The engine also seems like it’s staying at a high rev rate for a few more seconds when I take my foot off the gas. I keep the AC blasting, and I know that’s a big draw from the battery, but I’ve always done that on hot days. MPGs are around 32 during this time period, about 10 lower than normal during the less hot months.
    The symptoms seem similar to what this person had, but my car is much older and has far more miles: 2013 Prius struggling in heat | PriusChat
    Any ideas would be greatly appreciated!
  2. Mendel Leisk
    41,931
    You could try Dr Prius (phone app). It requires an OBD Bluetooth dongle; Carista worked well for me, with an iPhone. Simple assessment looks like attached.
    BiomedO1 and Brian1954 like this.
  3. ASRDogman
    ASRDogman Senior Member
    7,836
    3,991
    Too many factors to give any real diagnoises....
    It does seem like your hybrid battery is weak. Is it original?
    It seems this issue began when you stayed in the city. The hybrid battery
    does take longer to charge up with city driving.
    Have you had the egr system cleaned? Changed the air filter?
    Since you don't want to do any work on it, you need to seem a good shop that
    is familiar with the Prius and get a diagnoised performed.
    Mostly what you'll get here is "guesses" as to what it could be. And it will only
    fustrate you.
    Since you don't want to do any work on it, you need to find a good shop that
  4. BiomedO1
    4,191
    2,187
    SacTown, Ca
    Yep, sounds like a weak traction battery. If the cooling fans in the traction battery pack has never been cleaned out - now probably a good time to do that and make sure it's operating correctly. It's probably too late but it sounds like a couple of weak cells in your traction pack. Your entire pack recharges back up in about 10 minutes, then your symptoms goes away. Once you park the car overnight the cycle repeats. If you don't blast your AC, the draw on your pack is lessen and you problem will probably go away for now.
    Hope this helps....
  5. PbRius2012
    New York
    The weird thing here is that it’s only happened this year, it’s only for the first 10 minutes or so, and only if the temp is 85-90+. Regardless, I got a reader and the Dr. Prius app. I ran the two diagnostics and they both were fine (battery pack registered 61% which was “fair”, and I guess fine for a 12 year old car). If anyone sees anything in these screenshots that is alarming, please let me know!
    For now though, I’m probably just going to drive it as is and just deal with those extra hot days as they come. I may attempt the battery fan cleaning, the Prius service center charges 180 for that and that looks like it’s worth taking the time to save the dime.
  6. Leadfoot J. McCoalroller
    8,150
    7,654
    Pennsylvania
    2018 Prius c
    Air conditioning often works harder (draws more power) in the first few minutes, assuming the car is parked outside in sunlight.
    Try a trip without A/C.
    My guess (and it really is a guess without direct diagnostics) is that your A/C load vs. a hot cabin is enough to make a "fair" battery act like a "poor" battery.
    After those first few minutes, the A/C energy demand slacks off, and there is more available for other duties.
  7. ChapmanF
    18,572
    If I watch the "A/C watts" PID on my ScanGauge while driving, I see the car often drops the compressor power to zero when I ask for any more than modest acceleration.
    Some old mopars and the like would have a "WOT Cutout" in the A/C clutch circuit, for the same reason.
    So I'd like to think it isn't the A/C sapping too much power when you're actually trying to accelerate....
  8. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    That's because you had windows closed in the parking lot and the battery pack was hot. Upon first using the car Use the air conditioner to cool the battery pack. The status you describe is protection from heating the battery up more
  9. douglasjre
    2,205
    736
    Null, NL
    BTW, do not plug it aftermarket dongles into the OBD Port.
  10. Lares_Mat
    Lares_Mat Member
    199
    59
    I can imagine, that something like this would happen, if the HV-Battery is simply too hot.
    The system is not allowing to charge or discharge the battery to protect it.
    The effects - the ICE hast to do all the work to accelerate the vehicle, and it is reasonable weak engine ;)
    And after taking the foot off the accelerator, the ICE has to slow down the vehicle too - without charging the, still too hot, battery, so it is revving up and not going down to idle.
    Does this sound plausible?
    Mat
    douglasjre likes this.
