Suspension
Discussion in 'Prius c Main Forum' started by Jarrod2027rus, Jul 22, 2024.
  1. Jarrod2027rus
    Jarrod2027rus New Member
    Illinois
    I own a 2012 prius c and recently added a hitch kit to it, prius c can haul up yo 2000 pounds for anyone curious. And i had a big engine on a trailer and was squatting quite a bit the whole way home, does anyone know any rear springs and shocks that are stiffer yet fits on the prius c? IMG_20240714_184358047.jpg
  2. John in Vermont
    John in Vermont Junior Member
    44
    17
    Rochester, Vermont
    2018 Prius c
    You loaded the trailer incorrectly. The load should be further back, over the trailer's axle, so the weight is on the trailer's suspension, not on the tongue.
    There should be some load on the tongue but only about 10% of the total trailer weight. At 10% of the weight on the tongue, the load on the hitch would only have been around 100 pounds, and the car would sit properly. I have a trailer for my Prius C that I use weekly, and I have never had a problem with the rear suspension on the car sitting too low.
    BiomedO1 likes this.
  3. Jarrod2027rus
    Illinois
    I know my loading was bad the people who loaded ot had it all the way forward and i moved it as far back as i physically could, but i would still love some stiffer suspension if possible
  4. BiomedO1
    3,141
    1,666
    SacTown, Ca
    Just an FYI; several people with Prius C here had to replace their rear structural independent suspension frame because of bad or broken wields. Tire was pitched, excessive toe- in or out.
    something to watch out for....
  5. John in Vermont
    44
    17
    Rochester, Vermont
    2018 Prius c
    You don't need a stiffer suspension. If the trailer had been loaded properly the load on the hitch would have been one hundred pounds, which would be no more than the added weight on the rear wheels of a single person in the rear seat of the car. Even loading the trailer to 2,000 pounds would only put 200 pounds of additional weight on the rear wheels and that wouldn't cause a problem. Looking at the photo of your car and trailer you probably had 400 pounds of weight on the hall hitch.
  6. John in Vermont
    44
    17
    Rochester, Vermont
    2018 Prius c
    Was the damage to the car's frame because pulling a trailer or just because of rust or accident damage. I just looked at the frame on my PriusC and saw no problems despite pulling a trailer at least once a week for four years. Tire wear has been excellent.
  7. BiomedO1
    3,141
    1,666
    SacTown, Ca
    That wasn't mentioned, but there was broken wield joints and rust involved. Not too common, but I'm sure towing would help this issue along.
  8. NyQuil
    NyQuil Junior Member
    30
    2016 Prius c
