Just need to vent...
Discussion in 'Fred's House of Pancakes' started by Mendel Leisk, Jul 6, 2022.
  1. fuzzy1
    10,174
    I have accumulated more first-hand failure experience now than 40 years ago, and have a better idea what to watch for.
  2. Mendel Leisk
    38,738
    Not shy to admit, my main issue is lifting tires back on. I've adapted: have the wheel "just" clear, no more than an inch. Roll the wheel/tire up, as close as practical, and oriented to suit studs. Tuck my toes under the wheel (around 4:30 and 7:30) and lift, while guiding onto the studs with my hands.
    John321 likes this.
  3. jdenenberg
    jdenenberg EE Professor
    3,852
    1,852
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Luckily for me the 15 inch Prius wheels are not too heavy. My wife's Subaru wheels are a bit heavier. At 81 I can still handle the job and should for the next few years.
    JeffD
  4. Mendel Leisk
    38,738
    Pretty much everybody-proof, but they didn’t see me coming. Cap says press-and-turn. Tried that till I just about injured myself. Then out to the garage, try vise and pliers: no dice. Two surgeries and a repeated application of pliers: it’s opened.
    ^one more hurdle, locking band has to be removed; it has deformations locking against sim on bottom edge of cap. IMG_5037.jpeg
    ^ telling, that even now pliers required to get it unscrewing.
    #1844 Mendel Leisk, Jul 24, 2024 at 2:09 AM
    Merkey likes this.
  5. ETC(SS)
    6,557
    I call those "Adult-proof" containers......
  6. Mendel Leisk
    38,738
    Had a similar cap on a tin of acetone; except it was mercifully easy to dissect.
  7. hill
    8,190
    Worked with a lot of teak oil in shipyards many years ago - & have some teak furniture as well. As that stuff begins to thicken / coagulate inside those caps - it becomes impossible to remove, due to the cap's safety feature & the oil turning to a form of glue. But for its cost - it's almost worth throwing out.
    #1847 hill, Jul 24, 2024 at 10:56 AM
  8. Mr.Vanvandenburg
    1,065
    370
    2020 Prius Prime
    I worked with a man much older than me. He could take an apple in his hands and twist it into two perfect halves. Seemingly with little effort. I’ve tried and nothing happens.
    Now I am getting even weaker. Sometimes I use diagonal wire cutters to snip at the caps.
  9. Mendel Leisk
    38,738
    Scenario: elderly man, sprawled on floor, dead, his unopened, childproof heart med bottle beside him.
    I sometimes have to break out the oil filter pliers, for spaghetti sauce jars.
    That bottle of peppermint essesnce oil though, was a non-starter. Your apple splitter guy could maybe wrench the neck right off it, but the cap was not going anywhere.
