Toyota Prius3 fuel consumption in mixed mode
Discussion in 'Gen 3 Prius Fuel Economy' started by Toyota expert, Jul 24, 2024 at 11:28 PM.
  1. Toyota expert
    Toyota expert New Member
    Yesterday
    Kyiv
    In mixed mode, the Toyota Prius consumes 6.8 litres of petrol per 100 km.
  2. Tideland Prius
    16,159
    Seems a bit high, even if the average speed is 70km/h. I'm usually around 5.1L/100km at a steady 110km/h. Is your highway speed greater than 130km/h? Maybe that's why.
  3. ForestBeekeeper
    ForestBeekeeper Active Member
    716
    276
    Maine
    I only use ECO or PWR modes. So I have no idea how the NORM or mixed mode works.
  4. ASRDogman
    ASRDogman Senior Member
    6,101
    3,275
    If you deactivate "ECO" mode, that will be "normal" mode.
  5. ForestBeekeeper
    716
    276
    Maine
    I understand how to get into the NORM mode. what I do not understand is the benefit of the NORM mode.
  6. ASRDogman
    6,101
    3,275
    I would "guess" it would run in a normal way.
    ECO would use the battery more, cut back on the a/c and such and more Economicly efficient.
    Power gives you the maximum power from the engine and hybrid battery. A more sporty feel.
  7. ForestBeekeeper
    716
    276
    Maine
    That is my guess as well.
    I have two Prius' because fuel economy is important to me. Therefore I mostly use ECO. I have no idea what fuel economy should be expected from the use of NORM.
  8. bisco
    49,513
    Just a small difference from my experience.
    I always used eco to capture any and every fraction of efficiency.
    I’m not sure if the o/p is asking a question or making a statement
  9. ChapmanF
    15,683
    The limits on the HVAC system are the only genuinely substantive changes made in ECO mode. It caps how hard the A/C will be allowed to run, and it disables the supplemental electric heat while the engine is warming up. Those limits are not imposed in the other two modes.
    Aside from those limits, these three 'modes' don't do anything but change the shape of the graph from pedal position to requested power:
    The concave-down version you get from PWR feels sportier because your early foot motion makes a bigger change in power request. The concave-up version from ECO is easier to modulate at typical power levels, because your small foot motions make less difference. The linear version you get in 'normal' mode pretty much splits the difference.
    Funny, just noticed the OP is the so-far only post ever made by the new member, so the rest of us have just guessed at what the OP even meant by "mixed mode".
    Brian1954 likes this.
  10. bisco
    49,513
    toyota must believe that the delayed throttle would save gas by changing driver behavior.
  11. ChapmanF
    15,683
    My behavior changes within minutes every time I change the setting.
    I drive in ECO most of the time, but turn that off on occasion when I want more A/C or heat.
    My next couple take-offs after turning ECO off are more on the exuberant side, because I push the pedal down the way I was used to in ECO. Then my brain adjusts and I'm back to driving the car the way I normally do.
    Then when I don't want the extra A/C or heat, I put ECO mode back on. My next couple take-offs are more on the sluggish side, because I push the pedal down the way I was used to. Then my brain adjusts and I'm back to driving the car the way I normally do.
