Brake pads worn. How much?
Discussion in 'Gen 2 Prius Main Forum' started by james909, Jul 28, 2024.
  1. james909
    james909 Member
    107
    Leeds, U.K
    Wheel squeaks when I rotate it. Not sure how much pad is left. Hard to get a good picture. Any thoughts?
  2. Mendel Leisk
    41,822
    With the first pic, I'm having a hard time figuring out what I'm looking at. There is an opening on the back of the caliper, that affords a pretty good edge-on view of the back pad, fwiw. They typically have a groove running the width of the pad at the midpoint. If that groove is gone or nearly gone, It's likely around time:
    With the second pic:
    That bit's the outer pad thickness, and it looks to be somewhat less than the backer plate (to the left).
  3. james909
    james909 Member
    107
    Leeds, U.K
    Hi Mendel. The second pic - I measured the thickness with a small flat head screwdriver and it wasn't much more than 2mm. The first pic you can't really see the pad. What you can see is the brake pad wear indicator and it appears to be touching the rotor which explains the squeak. When I looked I estimate it was about 1mm of pad left. I was thinking of taking it into a garage tomorrow for new pads. Just wanted to make sure I hadn't got this completely wrong.
  4. Tombukt2
    13,270
    2,396
    You got a couple of days worth of pad material left need to get some pads pronto with them worn down so far You're either getting the rotors turned or new rotors your choice
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    The repair manual spec is 1 mm, but when wear indicators start squeaking, 1 or 2 doesn't really matter, just renew them.
  6. Mendel Leisk
    41,822
    It's somewhat like tire tread depth: you might still be "legal", but how low do you want to go.
  7. ski.dive
    ski.dive Active Member
    965
    244
    Hutchinson Island,FL. Mt. Snow,VT
    Brake pads are very inexpensive and easy to install=Replace them
  8. james909
    james909 Member
    107
    Leeds, U.K
    I got the pads changed for £60 by Viaduct Auto Repairs in Leeds. A very reasonable price and happy with the work!
  9. Mendel Leisk
    41,822
    #9 Mendel Leisk, Aug 1, 2024
  10. ski.dive
    965
    244
    I got my Prius brake pads on AMAZON.
  11. Mendel Leisk
    41,822
    I’d trust Amayama a lot more, regarding counterfeiting .
  12. ChapmanF
    18,453
