Yellowjackets -- the wasp/hornet
Discussion in 'Fred's House of Pancakes' started by Stevewoods, Aug 26, 2023.
  1. Stevewoods
    Stevewoods Senior Member
    649
    994
    Seattle, WA
    Been about 12 hours. Went to look-see. Lots (dozen or so) hanging and landing on entrance, flying off and replaced by others, but there is now a second hole about 8 inches from original and they seem to be using it. It appears to tunnel laterally for a bit.
    Really can't get a good look at original hole without major risk and can't see if they have cleared it, so hoping the original dusting will do them in, but I will risk it tonight and try to treat second hole and maybe get a better look at original entrance.
  2. Stevewoods
    649
    994
    Seattle, WA
    Second night strike. First hole pretty well covered except for small corner with insecticide. Bombed the additional hole, but unlike last night no guards appeared.
    .SHRUG....
    Well, will check in the morning.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,242
    5,939
    Columbia, SC
    The powder takes a few days as they walk over it and track it into the nest. When I "Sevin" powdered my yellow jacket ground nest, somewhere around day 4 there was zero outside activity. A few days later I got brave and dug, but had a can of wasp & hornet spray ready to go. The nest ended up being about 2' from where I saw them going into the leaves (the hole) and about an inch below dirt. It was ~6" diameter and 3 layers deep. There were several still alive at the bottom, including the queen. The spray took care of that.
    Stevewoods likes this.
  4. vvillovv
    vvillovv Senior Member
    3,693
    1,304
    NY
    Here see some pics of a now dormant nest, I kinda knew was being built as I could see the insects gathering the clay mud from a wet hole I'd dug in the backyard a few years ago. The reason I didn't see it for several months while the bugs were working as that best was the seeky devils built it above the garage doors and with the door up, when I was in there it (the nest) was out of site. When I finally pulled down the door while I was inside the garage I looked up and low I beheld the project in all it's working glory. I sheepishly closed the door and went online to see if I could figure out what to do about it. The one bit of advise that I took away from my search was "if you don;t want them to return next spring, just leave it where it is" and luckily in my case that is how it turned out. eeasy peesy ...
    28jul2024sda13-hornetsP1030641sca.jpg 28jul2024sda13-hornetsP1030642sca.jpg 28jul2024sda13-hornetsP1030646sca.jpg
  5. Stevewoods
    649
    994
    Seattle, WA
    Well, some 18 hours after my second overnight attack on the wasps and I see no activity at all near the nest.
    As mentioned above, it should take several days to dispatch the critters...so?
    It is unseasonably cool here today with a nice marine layer, so maybe they are staying warm below ground.
    Anyway, wifey will be disappointed as she was laughing quite a bit at my sliding down the hill after my treatments.
    OPPs, just saw one fly out. Looked to be more of a White jacket ... The color of the insecticide.:confused:
    #125 Stevewoods, Jul 28, 2024 at 6:46 PM
