Diagnostic Fee at dealer
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Falcon6v, Jul 29, 2024.
  1. Falcon6v
    Falcon6v New Member
    Tampa
    Four Touring
    Local dealer wanted $180 for a diagnostic. Isn't that just a scan? I can get it done for free at a lot of places. Anyone know why they charge so much? That's almost $150/hour?!!
  2. BiomedO1
    3,141
    1,664
    SacTown, Ca
    Because they can!
    Those places that do it for free will hook-up a $20 OBD2 scanner from Walmart and read-off generic Federally mandated codes. It's not a Toyota specific, Techstream OBD2 code reader that will tell you specifically whats going on and enable you to toggle sensors and switches to isolate your issue.
    Hope this clarify things.
  3. bisco
    51,525
    you can do your own with an autel maxi 200
  4. Mendel Leisk
    40,975
    I recall the first time I encountered that. Forget what the issue was exactly but it was clearcut. I phoned up service, made an appointment, brought it in, got the the phone call about an hour later, something along the lines of "Yes, that needs doing. Would you like to book an appointment to bring it in?" Yeah I guess so... :cautious:
  5. Leadfoot J. McCoalroller
    8,009
    7,484
    Pennsylvania
    2018 Prius c
    Proper diagnostics are much more than a scan, but most people don't know better.
    I'm not saying Toyota will do it correctly because that just isn't guaranteed. But as Biomed01 points out the dealer is supposed to do a lot more than the freebie places and they are supposed to use their experience to evaluate the results of their deeper scan in context with the symptoms reported.
    Doug McC and Brian1954 like this.
  6. Falcon6v
    Falcon6v New Member
    Tampa
    Four Touring
    There are two hybrid repair places that will scan for free. This is what i don't understand. The "Stealership" also wanted $380 for a radiator fluid replacement. I was like you're charging me to watch fluid drain? Its a 30min job at best?
