is there a setting to keep TracBatt between 15-85% to extend Batt Life?
Discussion in 'Prime Fuel Economy & EV Range' started by The Big Sleaze, Jul 28, 2024 at 5:29 PM.
  1. The Big Sleaze
    287
    63
    'frisco
    2020 Prius
    Two Eco
    My "new" renewed Samsung Note20 Ultra's setup included asking me if I'd like to set it to keep Battery between 15-85% to extend Battery Life.
    I remember Scotty Kilmer saying same should be done with E-Cars (or PHEVs). Is the a setting on a 2020 Prime to do that?
  2. pasta4breakfast
    pasta4breakfast Junior Member
    56
    25
    Southern California
    2020 Prius Prime
    I think Toyota automatically sets the traction battery to charge only between 15% to 85%, though the exact numbers are unknown. The battery size is 8.8 KWh. If you charge it from 0% to 100%, I doubt you will ever be able to add more electricity than 6.5 KWh. I have only been able to add about 5.3 to 6.1 KWh when charging from 0-100%. That means about 30% of the battery is off limits for the EV mode, some of it is a buffer at the bottom for the HV mode and the other is a limit for the top to protect the battery from being fully charged.
  3. bisco
    49,534
    toyota takes more care protecting your battery than phone companies, because cali forced them into a 10 year warranty
    pasta4breakfast likes this.
  4. dbstoo
    dbstoo Senior Member
    1,336
    711
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    That was part of the program that mandated making a significant percentage of their cars to be in the low/no pollution category, right? The program that
    That warranty was the smartest part of that program. In those days (circa 2000) the first buyers were taking an extreme risk because the EV's of the time were built with lead acid battery packs that needed frequent replacement. I was reassured by that 10 year / 150,000 mile warranty, even though I did not need it. It was that well designed / built. It was running well when I sold it after 17 years on the road.
    My thanks to Toyota and California for doing what it took to get it right.
  5. bisco
    49,534
    phones could do the same, if there was a mandate.
