No Ready Mode
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by thetruth127, Jun 1, 2024.
  1. rjparker
    8,009
    4,749
    I also doubt the 12v battery is your problem but if the system never gets to Ready there can be no 12v charging from the vehicle. So keeping your 12v on a charger makes sense.
    If you have some pin corrosion after being disabled by the ocean for six months there could easily be more.
    Certainly this is a problem. But I would make sure the fuse is not undersized. Lots of people have reverse jumped their cars without blowing modules but you may be the first with an advanced technology system. So all bets are off.
    I looked through both threads and their attachments and found little from the hv battery.
    It seems your can bus network is down but it could be the Techstream on your laptop in part.
    Honestly if this car is worth saving it might be time to find local help. Not sure where you are in California but I would start with cancelling all assumptions on what works, reinstall original modules, connect everything, verify each fuse by size, position and continuity, and then probably need to grid charge the hv battery.
    #21 rjparker, Jun 1, 2024
    thetruth127 likes this.
  2. JohnPrius3005
    JohnPrius3005 Active Member
    419
    227
    California and Hawaii
    What is the step by step procedure you would use when first walking up to the car and trying to get it to READY?
  3. thetruth127
    thetruth127 Junior Member
    37
    I have been checking the ecu fuses but I will have to recheck all the fuse especially the one under the fuse box which is a pain to get to
  4. thetruth127
    37
    Will do …to be continued
  5. thetruth127
    37
    Press the brake, press the start button , press for accessory mode , then again for ready mode
  6. thetruth127
    37
  7. Mendel Leisk
    38,760
    With brake pedal depressed one push “should” get you into Ready. There’s a gizmo at brake pedal to detect if it’s depressed, maybe not working?
    thetruth127 and Air_Boss like this.
  8. JohnPrius3005
    419
    227
    Try these steps:
    Disconnect one of the terminals from the 12v bat
    Measure the voltage with a voltmeter
    Locate the procedure for attaching a Prolong HV bat system.
    From this procedure determine where the Prolong is attached.
    Measure the voltage of the HV bat.
    Tell me each of these values and I'll give you the next steps
  9. thetruth127
    37
    The 12v is reading around 12.20
    I tried googling your other recommendations, do you mean a Prolong hybrid battery charger? the modules are reading around
    6/3/24
    1/7.53
    2/7.67
    3/7.55
    4/7.53
    5/7.55
    6/7.57
    7/7.55
    8/7.55
    9/7.56
    10/7.57
    11/7.56
    12/7.55
    13/7.58
    14/7.55
    15/7.03
    16/7.09
    17/7.53
    18/7.56
    19/7.55
    20/7.55
    21/7.56
    22/7.23
    23/7.59
    24/7.53
    25/7.55
    26/7.56
    27/7.58
    28/7.57
  10. thetruth127
    37
  11. JohnPrius3005
    419
    227
    12.2 v "might" get the car to ready.
    I recommend charging the 12v bat with it disconnected. See how high you can get it to stabilize at after 8+ hours of charging.
    Otherwise get your hands on a known good battery - any 12 v car battery - and connect that alone to the car, with the original bat disconnected.
    Yes, that Prolong. What the instructions will do is show you how and where to connect it. This is where you want to measure the HV bat voltage. I'm not asking for module voltages.
  12. thetruth127
    37
    So the fuse 10 amp ECU -IG no.2 is still blowing when the DRIVER ASSIST CONTROL MODULE OEM 86572-47030 is contacted when the car is put in accessory mode tracing some of the wires to these boxes , what are they ? I was thinking of disconnecting the wires going into them to see if the test light that I have connected to the fuse slot goes out or is there a better way any input on narrowing down the this issue is appreciated.
  13. thetruth127
    37
    When the driver assist is disconnected there is a click when powered from the seat belt control ecu and the power steering ecu/ when the driver assist is reconnected no response from either
  14. rjparker
    8,009
    4,749
    That module simply controls the pedestrian alert speaker in front as far as I can tell. I seriously doubt it is needed or is keeping you from Ready.
    Other items on that fuse are important.
    However the pics you are showing are not it.
    #34 rjparker, Jun 6, 2024
  15. thetruth127
    37
    Agreed but the fuse which is being blown is responsible for many
    systems that it functions :
    Audio System (Radio & Display Receiver Type) Automatic Glare-Resistant EC Mirror
    Cruise Control
    Dynamic Radar Cruise Control
    Engine Control
    EPS
    Garage Door Opener
    Headlight Cleaner
    Hill-Start Assist Control
    Hybrid System
    Navigation System (Navigation Receiver Type)
    Navigation System (Radio & Display Receiver Type)
    Parking Assist (Rear View Monitor) (Navigation Receiver Type) Parking Assist (Rear View Monitor) (Radio & Display Receiver Type) Pre-Collision System
    Roof Sunshade System
    Shift Control System
    Tire Pressure Warning System
    TRAC
    Vehicle Proximity Notification System VSC)
  16. rjparker
    8,009
    4,749
    Exactly. My point was IF that module is the same as what I pictured leave it disconnected.
    It is unlikely to be needed for Ready.
  17. thetruth127
    37
    KZYEE KM10 Power Circuit Probe
    Test results
    1.yellow /probe powered car off no reading / coming from the TPMS reset/set button :resistance 37.8k /continuity 2.75v
    2.purple / voltage 4.3 none powered/waveform 4.5 max 4.2 min frequency no powered/no resistance/continuity .0L
    3.blue/voltage 4.2 none powered/waveform 4.3 max 4.0 min freq no powered/ no resistance / continuity .0L/ coming from box : voltage 4.0v/waveform max4.2 min3.9/
    4.grey/resistance 10.5k/continuity 1.38v
    From the connector/ voltage 4.0v/waveform 4.2max 3.9min/resistance 0L/continuity .0L
    5.yellow /resistance 2.0k/continuity 1.54v : connector coming from instrument panel resistance 1.8k /continuity 1.45v
    6.pink/resistance 6.0k/continuity 1.24v/ coming from connector no reading
    7.light blue /voltage beeps red dot no power 11.1v powered 12v/ waveform 11.2 max 11 min/ coming from box getting reads
    8.black&white/voltage green light 0.0v/ resistance flicker 15.1 beeping / coming from box : voltage green beeping ground/resistance 0.0v beeps/continuity 0.00v
    9.pink/resistance 8.6k/continuity 1.93v/ coming from box getting resdings
    10.blue/no reading
  18. thetruth127
    37
    this is the brake actuator, does it sound good ?
