TPMS (tire pressure) malfunction (?) on 2015 Prius V
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Badger52, Jan 9, 2024.
  1. DogDaze
    DogDaze Member
    203
    44
    Bay Village
    I did get the Autel MaxiTPMS kit last night.. I didn't get to spend a lot of time with it, but enough to confirm the Right Front sensor is bad. The other 3 are showing OK and Battery Life OK.. so a matter of getting that one swapped out at a small tire shop sometime soon, or hold till the fall when I plan to put new tires on.. nice to know I might only need to replace just the one that has apparently died.
