Engine swap Trouble codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Melthias, Jul 31, 2024 at 7:42 AM.
  1. Melthias
    Melthias Junior Member
    58
    22
    Southern Maine
    About one year ago I bought a 2012 prius with a blown head gasket and swapped that engine out for a JDM engine (see here) and after diagnosing running rough as counterfeit plugs it has been running great.
    2 weeks ago I bought a 2011 prius, this time with legit holes in the engine due to a head gasket failure followed by hydro lock in cylinder #1. I got another JDM engine and looked it over inside and out. To me the cylinders seemed to have very little carbon, and the oil I drained out was in good condition. The EGR cooler was still really clean (could see light through it) so I went ahead and dropped it in yesterday.
    I finished hooking everything up this morning, and just pressed the start button. Things were really smooth for the first few seconds, but then got very rough.
    When I scan it I get several codes:
    Permanent:
    P3190 Poor Engine Power
    P3191 Engine does not start
    Others:
    U0073 Control Communication with Bus "A" Off
    U0123 Lost Communication with Yaw Rate sensor Module
    U0124 Lost Communication with Lateral Acceleration Sensor Module
    U0126 Lost Communication with Steering Angle Sensor Module
    U0293 Lost Communication with Hybrid/EV Powertrain Control Module
    When I bought the car it had the p3190 already. I did not scan all the modules, so it could have had the U0XXX ones as well.
    I of course am wondering "Did I plug everything back in?" I did take my time with hooking things up, and I have done this once before. From the top of the engine I can't see anything that is disconnected. I am using the plugs, coils, and injectors from the JDM engine. The condition of the plugs looked fine to me, and they looked legit, but I of course have been fooled before. I DID put oil in the engine, something that I somehow forgot to do on the one last year and quickly realized my mistake.
    The communication codes make me think that there is some kind of ECU or electrical issue. This did sit for about 9 months before I bought it.
