When to look for a new car
Discussion in 'Gen 3 Prius Main Forum' started by Michelle McConnell, Jul 30, 2024.
  1. Michelle McConnell
    Michelle McConnell New Member
    Bellefonte, PA
    My son has been using my 2014 Prius, and it's just shy of 200K miles. Basically, it died in the driveway about a month ago. We had it towed to the dealership, and they took 2 weeks to diagnose it. My son was told it needs a new short block, there was barely any coolant in the engine, cylinder 1 misfire and "probably more". 8 grand to fix.
    I obviously don't want to sink that much money into it. What are our viable options? Should we sell it for parts (which will require another tow but we have AAA)? Thanks in advance for any advice.
  2. Tombukt2
    12,682
    2,264
    Common very common run Don't dillydally don't walk run quickly You don't want any part of this there are plenty of cars in the universe and all that kind of nonsense Don't even fool with this It's quite silly unless you can show me almost brand new looking 2014 whatever it is forget it these are not keepers never will be they're glorified taxi cabs maybe. Will be interesting to see what you will consider and eventually purchase.
  3. ASRDogman
    ASRDogman Senior Member
    7,427
    3,867
    You can get a remanufactured engine from the hybrid pit for less than $3000.
    Are you able to install it yourself? If not, find an independent shop that will do it for a LOT
    less than the dealership.
    You can also search for a used motor from Toyota, JDM? I just think of the name of them.
    Not sure if JDM is correct or not, but someone else will chime in. They are usually around $1500,
    and supposed to only have around 50,000 miles on them.
    I woulnd't get one from a junk yard, because you don't know what shape it's in.
  4. Mendel Leisk
    40,975
    See what an independent would charge? Short block and gasket kit (included head gasket), through Amayama:
    Buy Genuine Toyota 1140037140 (11400-37140) Block Assy, Short. Prices, fast shipping, photos, weight - Amayama
    Buy Genuine Toyota 0411137310 (04111-37310) Gasket Kit, Engine Overhaul. Prices, fast shipping, photos, weight - Amayama
    best to replace head bolts too.
    be sure to clean the EGR too, more info in my signature. Other links head gasket related. Last link is full engine section from repair manual. (On a phone turn it landscape to see signatures)
  5. BiomedO1
    3,141
    1,664
    SacTown, Ca
    If no-one in your family knows how to work on cars, It's more economical to sell it for parts and recoup some if not all the diagnostic cost. Talk directly to the Toyota mechanic or place the car on Facebook market place or Craigslist as a parts only car. If the car is clean, the mechanic may buy it from you - cheap family transportation. I used to do that and give cars for cost to family and friends.
    On the other hand, new and used car cost are very high right now - so if you can budget for one vs a cheaper repair, Your choice....
    You should be able to get at least $750 for it, in it's current condition. As long as the car isn't ratted out (rolling junk pile). No offense.
    Hope this helps...
    #5 BiomedO1, Jul 31, 2024
    Michelle McConnell likes this.
  6. ASRDogman
    7,427
    3,867
    2010 2011 2012 2013 2014 2015 Toyota Prius Engine Hyrbid 2ZR-FXE 1.8L 2ZR CT200H | eBay
  7. bisco
    51,525
    i would sell it and buy a used corolla or similar. you're lucky to have gotten 200k before the first major expense, and the battery and brake actuator are still lurking...
  8. bbrages
    bbrages Member
    164
    47
    St. Louis
    I bet you could get $2000 from an ambitious DIYer if it's in good condition inside and out.
    bettergolf likes this.
  9. Leadfoot J. McCoalroller
    8,009
    7,484
    Pennsylvania
    2018 Prius c
    Sounds like you got your money's worth.
    it's absolutely time to cut the cord on that one. Sell for parts if able or donate for a tax credit if that doesn't work. Good luck!
  10. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Referring to the original post here,
    Is it common for the Prius to die in the driveway like described or should there have been warning signals ahead of time? If yes to warnings, what would some of them have been?
  11. MelonPrius
    839
    516
    Nevada
  12. Andy Pants
    Andy Pants Member
    35
    27
    WIsconsin
    Sounds to me like the head gasket went bad, which is *normally* noticeable before it completely dies. Most noticeable sign would be rough starts, especially after sitting overnight (coolant leaks into the cylinder causing misfire). Also obviously your coolant level would be going down once the gasket starts leaking.
  13. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    Third planet from the Sun
    No maintenance or control over fluid levels. A natural result.
