Why Are Tires So Hard To Replace For The Prime?
Discussion in 'Gen 5 Prius Main Forum' started by FarTraveler, Jul 27, 2024.
  1. ArtVanDelay23
    ArtVanDelay23 Member
    61
    62
    ny
    19 inch wheels on a Prius is the equivalent of someone in the 1950s not being aware that smoking cigarettes is harmful. You don't need a warning label or scientific study to know 19 inch wheels is an example of planned obsolesce.
    52,393
    oddly, tyre size was one of the things that prevented me from buying a new prius.
  3. soft_r
    soft_r Active Member
    188
    155
    Beverly Hills
    2024 Prius
    You can LITERALLY go out and buy new wheels and tires and sell the OEM ones.
    How are you an adult? Like, how do you have a job, maybe a family, you have grown up responsibilities but you throw your hands up in the air and claim defeat because you didn't like a car's OEM tire size? They use a common lug pattern with a common bore size (which you can also buy adapter rings for), and selling the OEM wheels and tires would be enough to pay for a different set in the size you like.
    Like I'm not trying to be all "you got soft hands brother" because I work in management, but holy shit Prius drivers really are softer than baby poop. It's a very minor problem with a very easy solution and that defeated you?
    dbstoo and reservoirblue like this.
  4. bisco
    52,393
    i said 'one of the reasons', there were many. are you this nice to people in real life?
    Jabog6, Illini Al and Trollbait like this.
  5. Mendel Leisk
    41,908
    I had no idea who you were responding to. :whistle:
    Trollbait and bisco like this.
  6. bisco
    52,393
    LOL, i get it
  7. Trollbait
    12,688
    Toyota doesn't just make cars for North America. Comments during the gen5 release made it sound like the tire sizes were already available in Japan. It is not a case like the i3 where BMW had to work with a tire company to make that size for the car. (note: Those even narrower tires will fit the gen5 wheels for those looking for better efficiency) Availability will expand.
    The fuel efficiency meant Toyota kept the tire width the same. Sounds like the higher performance required a larger contact patch though. Larger diameter was to only way to get that. This size could become common on EVs.
  8. Mendel Leisk
    41,908
    Daughter's Tesla 3's 235/45R18. Quite heavy.
  9. bisco
    52,393
    i don't like teslas tyre sizes either. at least the larger ones are an option.
  10. Mendel Leisk
    41,908
    Just for giggles (45.33 lb's):
    Illini Al likes this.
