Transmission "Flush" with syringe
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Anklepain, Jul 30, 2024 at 4:12 PM.
  1. Anklepain
    Anklepain New Member
    Finland
    2014 Prius+ MPV
    What do you think about transmission "Flush" with syringe. Im thinking to suck the bottom fluid out from the draining hole with syringe. Would it be safe to do it that way? Is there something need to be conserned?
  2. BiomedO1
    1,494
    810
    SacTown, Ca
    How are you going to properly refill it?
    What if you can't get the fill plug off?
    Do you know what a "drain plug" is? Why would you have to suck it out with a syringe?
    How big is this syringe? It would need to be able to move 4L of ATF in one go, so you can get that drain plug back onto place without losing too much ATF. :(:eek:o_O:censored::sleep:(n)
    FYI; a proper flush would involve disconnecting the ATF cooling lines from the radiator. ATF going into the radiator gets dumped into a can, the new stuff goes back to the transmission on the return line. There's no good reason to flush this transmission, it's a planetary gear style.- so most of it's wear happens during break-in.
    #2 BiomedO1, Jul 31, 2024 at 12:16 AM
  3. xliderider
    xliderider Senior Member
    7,876
    3,117
    Honolulu, HI
    Agree with the post above. OP, you're over complicating a simple drain and fill operation.
    It's very similar to an oil change. Open fill plug, remove drain plug and let gravity do its thing. Replace drain plug, and fill the transaxle either with a funnel and tube, or you can use your syringe.
    SM-G781V ?
  4. bisco
    49,545
    only problem is you need a lift or four jack stands
    xliderider likes this.
