Time to replace 12v battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by twosinks, Jul 31, 2024 at 5:33 PM.
Tags:
  1. twosinks
    twosinks New Member
    Monday
    Georgia
    the 12v battery in my 2013 Prius reads 11.6 volts before startup and then once I turn the car on it jumps up to 14.3v is this normal? Or is it time to replace the 12v battery? I found this information in the diagonstic menu... I assume that the information provided is for the 12v battery, and not the Hybrid battery.
    There is no trouble turning the car on and there is no signs of a dying battery like dim interior lights nor an illuminated check battery light on the dashboard.
    #1 twosinks, Jul 31, 2024 at 5:33 PM
  2. Brian1954
    Brian1954 Active Member
    864
    319
    South Central PA, USA
    How old is the 12v battery?
    You could try using a battery charger and see how the battery responds before buying a new battery.
  3. Stevewoods
    Stevewoods Senior Member
    650
    997
    Seattle, WA
    How are you "reading the 12v number."
    Basically, if your battery is below 12.4 volts you are living on borrowed time.
    The battery needs to hold above 12.4 all by itself to be considered viable.
    #3 Stevewoods, Jul 31, 2024 at 7:42 PM
  4. bisco
    49,550
    if it's original, replace it with a new oem
    Stevewoods likes this.
