  1. ReshiElderberry82
    ReshiElderberry82 New Member
    Atlanta
    I just replaced the brake pump and actuator on my 2013 toyota prius and i'm having trouble connecting to the unit with scanner tool which is MaxiSys MS906TS. When i try to preform the brake bleeding procedure i get a message that says "Device unable to communicate with the control unit." any help would be greatly appreciated. maybe a different scanner tool or any other suggestions would be a lot of help.
    thanks
  2. Tombukt2
    9,256
    1,624
    Sometimes this happens You got to make sure if you haven't looked at the factory manual dialogue there's all kinds of things the parking brake has to be down and so on and so forth I don't know whether the aultel system gives you those primers at the beginning of each step or the start of the system whatever so you may need to check that usually when you get that message you haven't done something that needs to be done before you start the whole business.
    ReshiElderberry82 likes this.
  3. ReshiElderberry82
    Atlanta
    yeah i think so, i've ordered a new usb cable to make sure its not that. i will check again tomorrow when i get it. the battery 14.76v. i attached a NOCO Boost Plus 12.V 1000A to the battery to make sure the car battery doesn't die. here is a photo of what pops up when it won't connect.
  4. Brian1954
    Brian1954 Active Member
    865
    319
    South Central PA, USA
    Did you buy a new OEM brake pump and actuator or used parts?
  5. ReshiElderberry82
    Atlanta
    i got them off ToyotaPartsDeal. they look brand new but i guess you never know.
  6. Tombukt2
    9,256
    1,624
    They probably should be brand new I guess that they look like it I see an orange light on your scanner I'm assuming that's not the VCI light I'm assuming you have the VCI light and check mark is green indicating there's communication does your VCI cable or plug not flash green when data's moving or something like that? But there are things that have to be done to the vehicle before all of this works the parking brake has to be down you want to be not ready but in ACC or whatever it is with all the lights on whatever it tells you in the factory manual Chapman or somebody will pop it up here for you in a few minutes and if you don't do all that then highly likely it won't work but I'm thinking that when I had this problem because the parking brake wasn't depressed or something like that it didn't talk about communication problems I don't think but it might have I very quickly figured out that my parking brake wasn't down.
  7. ChapmanF
    15,739
    The orange light on the scanner is tire-warning-shaped, decorated to suggest radio waves. I wonder if this scan tool is one of those you can also use to read your tire pressure sensors.
    Tombukt2 and ReshiElderberry82 like this.
  8. ReshiElderberry82
    Atlanta
    I wanna thank you guys for your help. i tried it again and i realized that i have to turn the car on and then put the parking brake on then start the procedure. it worked for bleeding the brakes, but i cant go into calibrating the linear solenoid valve because i can't turn the car on (ready off) because the brake lights are on so im assuming the car thinks i have the brake pedal on so when i hit the on button it just cranks like if i had the break pedal down. would that indicate the parts i bought are broke or is there something i can do to fix the issue?
    Again thanks so much for the help. im not very car savvy. up until a few months ago i didn't even change my own oil, but then the head gasket had to be replaced and i did that with some help from people on this forum. now im trying to do this brake pump and actuator, so yeah thank you guys. i really appreciate it the help.
    after i did the brake bleeding these are the codes that are still popping up
  9. ChapmanF
    15,739
    There is a button above the brake pedal that controls the brake lights. When the pedal is released it comes all the way up and pushes the button, and the brake lights are off. When you brake, the pedal moves down away from the button and the lights are on.
    If the released pedal isn't coming up high enough to push the button and turn the lights off, something needs to be adjusted. I'll mention the adjustments in reverse order of likelihood (you'll see why).
    1. (last resort) The button itself is adjustable if needed. You never touched it, so it shouldn't be needed, so only touch this if the steps below haven't fixed the problem.
    2. The brake pedal height when released is adjustable, using the clevis on the cylinder pushrod. The pedal height should be adjusted to the measurement in the drawing below. But only touch this clevis if the step below hasn't fixed the problem.
    3. (First thing to do) Recheck how you mounted the new unit to the firewall. Make sure it is not cockeyed, nothing is stuck in between, holding it away from the firewall. If it came with a gasket to go between the unit and the firewall, make sure the old gasket isn't still stuck on the firewall too.
    Only if you are absolutely sure that the unit is mounted flat down on the firewall where it belongs, then measure the released pedal height as shown in this drawing, and if it isn't right, make it right as described in this post.
    Note the measurement is from the bare metal floor, so the carpet has to be folded back.
    Only if you have measured the pedal height and you're sure you've made it correct, and it still isn't pushing the button to turn off the brake lights (this is darned unlikely), then you would adjust the button itself.
  10. ReshiElderberry82
    Atlanta
    Thanks for all the help guys. i really can't take you enough. im gonna try it out in the morning and hopefully i can get it all worked out. i will let you guys know how it goes. really pumped on getting in there tomorrow and getting it fixed.
  11. Tombukt2
    9,256
    1,624
    Yes I think this a u t e l scanner It's a 906 or something like that is based upon their TPMS software also so it can program there a u t e l TPMS sensors as well as generally strike up relearns and all that with other sensors on various makes and models of cars this series of scanner comes this way It seems like they're touting the TPMS part of the whole scanner more than they are code reading and maintenance which you have to be careful with this brand they make models of each series for homeowner DI wires and then the $4,000 model for the shop with all the plugs and the case and all the nonsense that goes with it.
