Prius gen 2 low hanging exhaust pipe?
Discussion in 'Gen 2 Prius Main Forum' started by Has Raf, Aug 1, 2024 at 1:57 AM.
  1. Has Raf
    Has Raf New Member
    Today
    Stoke-on-Trent, England
    Hi all. Is this pipe too low? I went over a speed bump and heard a metallic clang. It was one of those speed bumps that your wheels just glide over it on either side of it, but it’s raised in the middle under the car, if that makes sense. The bumps wasn’t the width of the road. IMG_2101.jpeg
  2. Tombukt2
    9,258
    1,624
    Any exhaust guy I'll have that fixed up in 5 minutes No problem It's way too low needs to be heated and pushed up with the pipe holder let the exhaust guy uses I make them put mine up tight against the car but not touching anything so I can go over things without it ever scraping It should not be scraping It may also be getting time for springs and struts which has no bearing on this exhaust issue
  3. Mendel Leisk
    38,765
    @Has Raf can you clarify orientation/location of pic? Is that near the back, just behind engine, what side, it’s a front wheel or back wheel showing?
    N’mind: as Tom says, hie thee to muffler shop.
  4. qmanqman
    qmanqman Active Member
    313
    112
    CO
    Just name your car Wun Hung Lo
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,254
    5,949
    Columbia, SC
    Something looks unusual with the bends on that pipe. I wonder if this car had its catalytic converter, etc stolen somewhere in it's recent life and it now has some aftermarket pieces installed? I've seen some where the new cat pipe is a clamp design and gets installed without actually positioning the downstream pipe correctly. Not everyone rotates the pipe prior to clamping to ensure the correct road clearance is maintained. If so, all it takes is loosening the clamp, put a pipe wrench or channel locks on each pipe and spin the downstream one just a fraction of an inch to make that section of pipe lift up.
    I just don't know...something about that bend looks really odd where it disappears and should go to the resonator
