TOYOTA Prius V AUX USB INPUT PORT P/N 86190-48030
Discussion in 'Prius v Audio and Electronics' started by Air_Boss, Aug 1, 2024 at 9:21 AM.
  1. Air_Boss
    Air_Boss Senior Member
    3,967
    1,087
    New Yawk
    Any one know whether the TOYOTA Prius V AUX USB INPUT PORT P/N 86190-48030 installed in the lower front console has an integral fuse or fusible link? Not getting power or connectivity to head unit. Thanks.
  2. rjparker
    8,017
    4,754
    No fuses likely but you could ohm out the wires. I give it 95% no internal fuse as Toyota and everyone else typically current limits usb charging power.
    It appears half of the wires go to the ext box and the other half go to the head unit.
  3. Air_Boss
    3,967
    1,087
    New Yawk
    Thanks. Guess I need to break it down again.
    In your photo, which connector goes to the console USB module?
