2021 Prius Prime XLE Non-JBL Speaker Upgrade TIPS and OBSERVATIONS
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Johninator, May 5, 2021.
  1. EdPalmer42
    EdPalmer42 Member
    121
    67
    2020 Prius Prime
    Yes, something like that. It's a pain to install because there are lots of plastic braces molded into the inside of the grill so you have to cut pieces of the weatherstripping to fit between the braces, then, depending on the size of the weatherstripping, you might need a second layer tp actually get to the speaker. Annoying & tedious! I would have mounted the foam on the speaker, but there's no place on the rim to stick the foam to.
    If you stand outside the car and look down at the speaker you should be able to look through the grill and see where the ring ends relative to the cone. Lighting isn't good - you might have to do it in the dark with a flashlight. Another test is to measure the diameter of the ring and compare it to the diameter of the cone. The ring is much smaller than the cone.
    Bottom line is that even though the speaker fits, it isn't really compatible without some work. I'm guessing that the same would apply to other speaker brands.
    Ed
  2. SergeT
    SergeT Junior Member
    Lithuania Klaipeda
  3. SergeT
    Lithuania Klaipeda
    Hi. I bought the same Cerwin Vega VPAS10. Question: how did you connect it to the system? I have already organized battery power supply.
  4. vvillovv
    vvillovv Senior Member
    3,715
    1,309
    NY
    Any good leads or these still all in the upper price range?
    Great write up and pics.
    this is all I've got so far.
    Neodymium Speaker Magnets Explained - Official FluanceĀ® Blog
    Saw a tube the other day bout how to get at the dash tweeters. thanks for the head up with the tweeter ring spacing.
