Right signal
Discussion in 'Prius c Main Forum' started by scottherock, Jul 18, 2024.
  1. scottherock
    scottherock Junior Member
    tampa
    I hit a deer while back and it took out my right side signal light assembly. The plug still works but I dont know if I could put a whole new assembly in. The bumper on that side was not dragging the ground but pretty damaged. I ran a bungy to make it more stable. I hate not giving a signal. Any ideas to rig something up easy using that plug that would be lighter and less bulky than the whole assembly.
  2. Mtn-Goat
    Mtn-Goat New Member
    Here
    2015 Prius c
    Photos would be needed to give better suggestions. You can take off the lower covers and bumper without a jack and 10mm. Tape off the lower portions of the headlights to avoid scratching the plastic on reassembly. Drift stitch the damage then grab a used signal housing and secure it (L brackets/zip ties).
